linker errors
dbuhl
I am trying to compile code to work on a computer with multiple 64bit Opteron processors in Windows Server 2003 64x. So, I am using the em64t compiler with the MS Platform SDK AMD64 linker. My code compiles ok, but the linker gives a bunch of errors similar to:
LIBCMT.lib(cvt.obj) : error LNK2001: unresolved external symbol __security_check_cookie
Am I missing something simple, or am I off-base in trying to use the em64t compiler with the SDK AMD64 linker. Can I even compile code w/ Intel Fortran to run on my Opteron machine? Any help will be much appreciated. I don't really know what the heck I'm doing.
thanks,
Dillon
jimdempseyatthecove
Dillon,
LIBCMT.LIB should be excluded from link. In the VS solution explorer.
Link Property Page
Input
Ignore Specific Library: enter LIBCMT.LIB
Jim Dempsey
Please read the compiler release notes for information on the "security_cookie" error and how to deal with it. Jim's suggestion is not the one I would recommend. Yes, Intel Fortran is supported for use on AMD processors.
dbuhl
Thanks for the prompt replies. The fix described in the release notes seems to work.
-Dillon
