linking a .dll in my project
david_sallngc_com
Hi!
I have a Fortran code that requires a particular .lib file to run. Some time ago, I was advised (on this forum), as a simple solution, to add the .lib file using the Project-> Add Exisiting Item, and then compile, which I have done and this has worked perfectly. Doing this though, required me to make a copy of the associated .dll and put it in the same directory as the Intel generated .exe file.
Is there a way of easily including the .dll by means of a directory name where it resides as opposed to me having to copy it to the same directory as the .exe? I can not seem to find the proper place in the Project Properties to add the particular .dll file name.
Thank you very much for your help.
Sincerely,
David
No, that's not the way Windows works. There is nothing in the executable that identifies the DLL other than its name, and Windows looks in a specific set of places for the DLL. The article at the link mentions DLL redirection, but that's no longer supported. It's possible you might be able to do this with a manifest, but I am not familiar enough with these to know the details.
If this is a DLL you use a lot, add its folder to the system PATH environment variable, and you'll be all set.
