linking c++ and fortran code
isomorphismus
Hello everybody,
I want to call a c++-function in a fortran program, using Compaq Visual Fortran as a Fortran compiler and Microsoft Visual C++ as a c++ compiler. I have written the following pieces of code:
the fortran main program:
program frotc
implicit none
integer :: x,y,max
write(*,*) "Bitte geben Sie zwei Zahlen ein: "
read(*,*) x,y
call sum(x,y,max)
write(*,*)"Das Maximum ist: ",max
end program frotc
and the to-be-called c++ function:
extern "C"
{void_stdcall max(int*,int*,int*);
void max(int*x,int*y,int*max){if(*x<=*y) *max=*y;
else *max=*x;
but I have no clue how to link these two programs together. Id be grateful for every piece of advice!
Isomorphismus
danhoyt
If you're linking the two together, the process is pretty straighforward (this example is for VS.NET2003 with IVF):
  1. Create a new, empty solution in VS
  2. Create a new C++ Library project
    1. Change your function paramsto use refs instead of pointers.
  3. Create a new Fortran project and make these property changes in ALL configs:
    1. Change Fortran|External Procedures: "C, REFERENCE"
    2. Add Linker|General|Additional Library Directory: "..{C_PROJECT}$(OutDir)" (replacing {C_PROJECT} with the dir from #2, usually the same as the project name)
    3. Add Linker|Input|Additional Dependencies: "{C_PROJECT}.lib" (replacing {C_PROJECT} with theoutput namefrom #2, usually the same as the project name)
    4. Add Debugging|Working Directory: "$(TargetPath).."
  4. Set Project|Project Dependencies so the Fortran project is dependent on the C project.
  5. Set Project|Set Startup Project to be the Fortran project.
I've attached a solution .ZIP with your code. Since I didn't include my user option files, you'll probably need to do step 3.4, but I think the rest will be done already.
BTW, If you want to do the C++ as a DLL, it's just a little more complicated, and it's easier to move all your projects into the root.
