linking modules using libraries
dnoack
my example program consist of three different parts. Each part is stored in his own file.
main.f:
program main
call sub
end
sub.f:
subroutine sub
use mod
write(*,*) 'logvar = ', logvar
end
mod.f:
module mod
logical :: logvar = .true.
end module mod
For mod.f I generate a static library as follows
ifort -fpic -c mod.f
ar rc modlib.a mod.o
After that I cleanup the temporary files with
rm mod.o mod.mod
Compiling and linking the entire program aborts withthe error
ifort main.f sub.f modlib.a
fortcom: Error: sub.f, line 2: Error in opening the Library module file. [MOD]
use mod
Please can someone explain to me, what is going wrong.
Dieter
You should not remove the .mod file. The .mod file does not go in the library but must be available to the compiler when you do a USE.
