29389 Discussions
localroot is an unrecognized argument when using Cluster Studio 19.2 and MPI
Anders_S_1
New Contributor III
I am running Cluster Studio 19 update 2 with Visual Studio 17, latest version. I use W10 Pro and MPI.
Everything works fine in Cluster Studio 18. With Cluster Studio 19 compiling and linking works fine but at run time I get the attached error message.
What can be done to get rid of this error?
Best regards
Anders S
jimdempseyatthecove
Does "mpiexec" no args show -localroot as an option (mine does).
Try -localonly or use -hosts YourHostNameHere
Jim Dempsey
Anders_S_1
New Contributor III
Hi Jim,
Many thanks for quick answers!!
-localonly solved the problem!
Best regards
Anders S
jimdempseyatthecove
On the Windows 10 desktop I am using to write this I can issue both:
C:\Program Files (x86)\IntelSWTools>mpiexec -hosts I72600K notepad
C:\Program Files (x86)\IntelSWTools>mpiexec -localroot notepad
 And four copies of Notepad launch (4 core CPU with host name I72600K).
Check where your mpiexec is located:
C:\Program Files (x86)\IntelSWTools>where mpiexec
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\mpi\intel64\bin\mpiexec.exe
C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt\mpiexec.exe
C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt\mpiexec.exe
C:\Program Files\Microsoft MPI\Bin\mpiexec.exe
C:\Program Files (x86)\Intel\MPI\5.0.2.044\intel64\bin\mpiexec.exe
C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\mpirt\mpiexec.exe
C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\mpirt\mpiexec.exe
On my system I see multiple copies, one of which is Microsof's the others are Intel's.
Try launching the Intel Parallel Studio (or Intel oneAPI) command prompt (32 or 64 bit as required), then CD-ing to the desired folder and then issuing your mpiexec.
Jim Dempsey
jimdempseyatthecove
Note, explicitly running the Microsoft version gets your error message.
C:\Program Files (x86)\IntelSWTools>"C:\Program Files\Microsoft MPI\Bin\mpiexec.exe" -localroot notepad
Unknown option: -localroot
jimdempseyatthecove
Anders,
There may be different features/capabilities with the Intel MPI library that you do not have with the Microsoft MPI library. So I would suggest you find out. I took the liberty to make a query for you over here.
Jim Dempsey
