log question
JohnNichols
Honored Contributor I
log(float(num))
if num is an integer, why not have a log function that can take an integer?
jimdempseyatthecove
See:
IEEE_SET_ROUNDING_MODE
 you can set to IEEE_DOWN, IEEE_NEAREST, IEEE_TO_ZERO, IEEE_UP, or IEEE_OTHER
IEEE_RINT using above mode
Jim Dempsey
JohnNichols
I was just playing as I waited from some runs to complete.  You have to do something.
And it generated some comment, you should try the MKL Forum.
