loop with integer to real qp Internal compiler error
pat97269
Hi ,
I have internal compiler error with the following code, trying to convert from int to quadruple precision inside a loop with at least -O2 . Compiler version 14.  It works with double precision.
program foo
      implicit none
      integer,parameter ::  q =  selected_real_kind(2*precision(1d0))
      real(q) :: k
      integer :: i
      do i=1,100
        k=real(i,q)
        print *,factorial1(k)
      end do
      contains
              function factorial1(n) result(res)
                      real(q) :: n
                      real(q) :: res
                      integer  :: i
                      res=1._q
                      do i=int(n),1,-1
                        res=res*i
                      end do
              end function factorial1
end program foo
pat97269
Just for information there is no problem with that version.
program foo
      implicit none
      real(q) :: k
      integer :: i
      do i=1,100
        print *,factorial1(i)
      end do
      contains
              function factorial1(nn) result(res)
                      real(q) :: n
                      real(q) :: res
                      integer  :: i,nn
                      res=1._q
                      do i=nn,1,-1
                      n=real(i,q)
                        res=res*n
                      end do
end program foo
Xiaoping_D_Intel
I have opened a bug report DPD200254996 and will keep you updated on it.
Xiaoping
