29649 Discussions
low performance caused by dynamically allocated memory
finback
a lot of dynamically allocated memory is used in my code. The code generated by Compaq Visual Fortran runs good. But when I use Intel Fortran Compiler for Linux to compile it, the performance drops terribly. I used gprof to dig out that this problem is related to several subroutines in which the dynamic memory is intensively used as well as pointers. But I don't know how to solve this problem. Does anybody have any experience or idea about this issue?
one of the subroutines mentioned about is give here. In the following code, the array elements of taLvl(level) are all dynamic memory.
Any suggestion or comments would be appreciated.
subroutine collect(level)
integer, intent(in):: level
integer iL,iGrpNum
complex cK,cEta
complex, dimension(:,:), pointer:: caCtrb2OutE, caCtrb2OutH
complex, dimension(:,:), pointer:: caCtrb2SonE, caCtrb2SonH
complex, dimension(:), pointer:: alpha
type(grp), dimension(:), pointer:: taGrp
integer g,m,n,iNbr,alphaIdx
iGrpNum=taLvl(level)%iGrpNum
iL=taLvl(level)%iL
cK=taLvl(level)%cK
cEta=taLvl(level)%cEta
taGrp=>taLvl(level)%taGrp
do g=1, iGrpNum
caCtrb2SonE=>taGrp(g)%caCtrb2SonE
caCtrb2SonH=>taGrp(g)%caCtrb2SonH
caCtrb2SonE=zero
caCtrb2SonH=zero
do n=1, taGrp(g)%iNbrNum
iNbr=taGrp(g)%iaNbr(n)
caCtrb2OutE=>taGrp(iNbr)%caCtrb2OutE
caCtrb2OutH=>taGrp(iNbr)%caCtrb2OutH
alphaIdx=taGrp(g)%iaAlphaIdx(n)
alpha=>taLvl(level)%caAlpha(:,alphaIdx)
do m=1, 2*iL**2
caCtrb2SonE(:,m) = caCtrb2SonE(:,m) + caCtrb2OutE(:,m)*alpha(m)
caCtrb2SonH(:,m) = caCtrb2SonH(:,m) + caCtrb2OutH(:,m)*alpha(m)
end do
continue
end do
continue
end do
end subroutine collect
david_a_levinthal
which architecture, X86 or Itanium, are you using?
Which build of the Intel compiler?
finback
I'm using 7.1 compiler for X86 on a RH9 OS.
