mexfunction and libifport.lib
david_sallngc_com
Hi!
I have written a FORTRAN MEX function that uses the FORTRAN function, "gettim". To use this function, you must include the module, "USE IFPORT" when compiling with the Intel FORTRAN 9.1 compiler. If I use the mex function in Matlab to compile my code and give it a direct path to the LIBIFPORT.LIB library, the compiled function works great.
mex junk.f90 "c:\Program Files\Intel\Compiler\Fortran\9.1\IA32\Lib\libifport.lib"
If I do not include "c\...\liifport.lib" then the mexfunction compiles but fails at runtime telling me about a dll initialization error. I checked the Matlab, "mexopts.bat" file and the library path is included to this Intel library but for some reason it is not linking properly.
Would it be possible for someone to take a look at the mexopts.bat file and tell me how I could tell the linker to include this directory?
Thanks you very much for your help.
Sincerely,
David
@echo off
rem INTELF91MSVS2005OPTS.BAT
rem
rem Compile and link options used for building MEX-files using the
rem Intel Fortran Compiler 9.1 with the Microsoft Visual Studio
rem 2005 linker.
rem
rem $Revision: 1.1.6.1 $ $Date: 2006/11/19 18:53:36 $
rem
rem ********************************************************************
rem General parameters
set MATLAB=%MATLAB%
set IFORT_COMPILER91=C:\Program Files\Intel\Compiler\Fortran\9.1
set VS80COMNTOOLS=%VS80COMNTOOLS%
set LINKERDIR=C:\Program Files\Microsoft Visual Studio 8
set PATH=%IFORT_COMPILER91%\IA32\Bin;%LINKERDIR%\VC\BIN;%LINKERDIR%\Common7\Tools;%LINKERDIR%\Common7\Tools\bin;%LINKERDIR%\Common7\IDE;%LINKERDIR%\SDK\v2.0\bin;%PATH%
set INCLUDE=%IFORT_COMPILER91%\IA32\Include;%LINKERDIR%\VC\ATLMFC\INCLUDE;%LINKERDIR%\VC\INCLUDE;%LINKERDIR%\VC\PlatformSDK\include;%LINKERDIR%\SDK\v2.0\include;%INCLUDE%
set LIB=%IFORT_COMPILER91%\IA32\Lib;%LINKERDIR%\VC\ATLMFC\LIB;%LINKERDIR%\VC\LIB;%LINKERDIR%\VC\PlatformSDK\lib;%LINKERDIR%\SDK\v2.0\lib;%MATLAB%\extern\lib\win32;%LIB%
set MW_TARGET_ARCH=win32
rem Compiler parameters
set COMPILER=ifort
set COMPFLAGS=/fpp /Qprec "/I%MATLAB%/extern/include" -c -nologo -DMATLAB_MEX_FILE
set OPTIMFLAGS=/MD -Ox -DNDEBUG
set DEBUGFLAGS=/MD -Zi /PDB:"%OUTDIR%%MEX_NAME%%MEX_EXT%.pdb"
set NAME_OBJECT=/Fo
rem Linker parameters
set LIBLOC=%MATLAB%\extern\lib\win32\microsoft
set LINKER=link
set LINKFLAGS=/DLL /EXPORT:MEXFUNCTION /MAP /LIBPATH:"%LIBLOC%" libmx.lib libmex.lib libmat.lib /implib:%LIB_NAME%.lib /NOLOGO
set LINKOPTIMFLAGS=
set LINKDEBUGFLAGS=/debug /PDB:"%OUTDIR%%MEX_NAME%%MEX_EXT%.pdb"
set LINK_FILE=
set LINK_LIB=
set NAME_OUTPUT="/out:%OUTDIR%%MEX_NAME%%MEX_EXT%"
set RSP_FILE_INDICATOR=@
rem Resource compiler parameters
set RC_COMPILER=rc /fo "%OUTDIR%mexversion.res"
set RC_LINKER=
set POSTLINK_CMDS=del "%OUTDIR%%MEX_NAME%.map"
set POSTLINK_CMDS1=mt -outputresource:"%OUTDIR%%MEX_NAME%%MEX_EXT%";2 -manifest "%OUTDIR%%MEX_NAME%%MEX_EXT%.manifest"
set POSTLINK_CMDS2=del "%OUTDIR%%MEX_NAME%%MEX_EXT%.manifest"
