migration to Fortran 64
meow
hi, I am trying to run a code that was written in fortran for 32 bits in a 64-bit machine. I did all changes and update links for libraries and include. However, I get a message that 'link_fnl_static_hpc.h' cannot be found. Any suggestions. I have gone over and over properly setting libraries and includes but doesn't work.
Pablo
That's an IMSL file. Have you installed IMSL for "Intel 64" and added the paths for the IMSL includes and libraries for the Intel 64 platform under Tools > Options > Intel Visual Fortran?
meow
Thanks Steve for your answer. Yes, I installed ISML for Intel 64 and added the libraries and includes ... Any other suggestions? I am already one day into this issue.
Pablo
My guess is that you have not set the INCLUDE path correctly for 64-bit compiles. See Installing and Configuring the IMSL Libraries. The file should exist in C:Program FilesVNIimslfnl600Intel64includedll.
If you still have trouble, please attach the buildlog.htm from a failed build.
