missing path?
Deleted_U_Intel
Greetings,
The code we are using is unable to rewind the input file. It generates the following error message. This code works previously using ifc 7.1.
Please advise.Thanks.
forrtl: info: Fortran error message number is 20.
forrtl: warning: Could not open message catalog: ifcore_msg.cat.
forrtl: info: Check environment variable NLSPATH and protection of /usr/lib/ifcore_msg.cat.
TimP
As to the failure to find the error messages file, the compiler installation should have put a symlink in /usr/lib to the file of the same name installed in the compiler directory. If you are running somewhere else, you may want to install a copy of that file, in order to get the original error message displayed.
