mixed programing
Muhammad_S_4
hello
i use intel compiler visual stdio(intel parallel 2015) to compile my project
console ( c source )
#include <stdio.h>
#include <stdlib.h>
#include <conio.h>
#include <string.h>
//#include <iostream>
//#define readfile readfile_
extern void readfile(char*, int*);
int main()
    int n, count;
    char Fname[9];
    char Name[10];
    strcpy(Fname,"AMIN.for");
    fprintf( stderr, "%s\n", Fname);
    readfile( Fname, &n, strlen(Fname));
    fprintf( stderr, "n = %d\n", n);
//  fprintf( stderr, "%s\n", Name);
    getch();
    getch();
    return 0;
subroutine ( Lib fortran )
      subroutine readfile( fname1, m )
      character fname1*(*)
      integer m
      integer iounit,i
      iounit=15
      write(*,*) fname1
c10   format (a9)
      open(iounit,file = fname1,action='read')
      read (iounit,*) m
c20    format (i10)
      write(*,*) m
      close(iounit)
      return
      end subroutine
this is my project and i don't have a problem
in this line i have a great problem
readfile( Fname, &n, strlen(Fname) );
i need to change line  ( is necessary for me)
readfile( Fname, &n);
is it possible? how to call without lenght character or how to calling convert to run and compile it correctly?
In addition i change "name case interpretation" to "lowercase"
when i compile it , my project cann't open file . i don't khnow why.
how to change setting vs2012 toget to it?
JVanB
Valued Contributor II
You could just change the prototype on the C side to
void readfile(char*,int*,size_t);
But then I don't know what happens with the trailing NUL character on the Fortran side. Maybe everything goes through OK, or maybe you have to do something like
LEN_FILE = merge(INDEX(fname1,achar(0))-1,len(fname1),scan(fname1,achar(0))>0)
and then subsequently use fname1(1:LEN_FILE) to open the file.
Also I tried some code where the C prototype changed to fit your requirements so the Fortran had to search for the terminating NUL character, and that worked out OK.
#include <stdio.h>
 #include <stdlib.h>
 #include <conio.h>
 #include <string.h>
int main()
     int n, count;
     char Fname[9];
     char Name[10];
     getch();
     getch();
     return 0;
      subroutine readfile( fname1, m ) bind(C,name='readfile')
       use ISO_C_BINDING, only: C_LOC, C_F_POINTER
       implicit none
       character, target :: fname1(*)
       character(:), pointer :: fname3
       integer m
       integer iounit,i
       i = 0
       DO
         if(fname1(i+1) == achar(0)) exit
         i = i+1
       END DO
       BLOCK
         character(i), pointer :: fname2
         call C_F_POINTER(C_LOC(fname1),fname2)
         fname3 => fname2
       END BLOCK
       write(*,*) fname3
10    format (a9)
       open(newunit=iounit,file = fname3,action='read')
       read (iounit,*) m
20    format (i10)
       write(*,*) m
       close(iounit)
       return
       end subroutine
JVanB
#include <stdio.h>
 #include <stdlib.h>
 #include <conio.h>
 #include <string.h>
int main()
     int n, count;
     char Fname[9];
     char Name[10];
     getch();
     getch();
     return 0;
       implicit none
       integer m
       integer iounit,i
       i = 0
       DO
         i = i+1
       END DO
       BLOCK
         fname3 => fname2
       END BLOCK
       write(*,*) fname3
10    format (a9)
       read (iounit,*) m
20    format (i10)
       write(*,*) m
       close(iounit)
       return
       end subroutine
mecej4
Here is one solution which requires little changes to the source code, but is not necessarily portable to compilers other than IFort. It uses the standard C function strlen().
Change the subroutine code to
      character fname1*(100)
      integer m, strlen, iounit
      character(len=:),allocatable :: fname
      fname=fname1(1:strlen(fname1))
      iounit=15
      open(iounit,file = fname,action='read')
      read (iounit,*) m
      write(*,*) m
      close(iounit)
      return
      end subroutine
and specify the compiler option /names:lowercase .
Ugh! I'd like to see /names outlawed....
Try this instead:
external strlen
!DEC$ ATTRIBUTES C, REFERENCE, DECORATE, ALIAS:"strlen" :: strlen
iounit=15
read (iounit,*) m
write(*,*) m
close(iounit)
return
end subroutine
FortranFan
No offense, but isn't it ugh! all around if we fail to fully recommend standard features for portable, easy-to-follow solutions :-))
@Muhammad S.,
Are you familiar with features in standard Fortran for interoperability with C (as well as a few other "goodies" available in the current standard for I/O)?  If not, you may want to look into them - the recommendations in Dr Fortran blog can help.  Using the standard features, you can write standard-conforming, portable code as follows:
module m
   use, intrinsic :: iso_c_binding, only : c_char, c_null_char, c_int, c_ptr, c_f_pointer
   use, intrinsic :: iso_fortran_env, only : output_unit
   implicit none
   private
   public :: ReadFile
   !.. Mnemonic constant for an arbitrary limit on file name length
   integer, parameter :: MAXNAMELEN = 2048
contains
   subroutine ReadFile( FileNamePtr, n ) bind(C, name="ReadFile")
      !.. argument list
      type(c_ptr), intent(in), value     :: FileNamePtr
      integer(kind=c_int), intent(inout) :: n
      !.. local variables
      n = -999
      blk_read: block
         character(kind=c_char, len=MAXNAMELEN), pointer :: TmpName
         character(kind=c_char, len=:), allocatable :: FileName
         character(len=80) :: ErrMsgIO
         integer :: LenFileName
         integer :: Istat
         integer :: FileUnit
         logical :: FileExists
         call c_f_pointer( FileNamePtr, TmpName )
         LenFileName = index( TmpName, c_null_char ) - 1
         if (LenFileName <= 0) then
            !.. appropriate messaging action elided
            return
         end if
         FileName = TmpName(1:LenFileName)
         inquire( FILE=FileName, EXIST=FileExists, IOMSG=ErrMsgIO, IOSTAT=Istat)
         if (Istat /= 0) then
            !.. error messaging action elided
            return
         else if ( .not. FileExists) then
            !.. appropriate action elided
            return
         end if
         open( NEWUNIT=FileUnit, FILE=FileName, ACTION="READ", IOMSG=ErrMsgIO, IOSTAT=Istat)
            return
         end if
         read(UNIT=FileUnit, FMT=*, IOMSG=ErrMsgIO, IOSTAT=Istat ) n
            return
         end if
         write(UNIT=output_unit, FMT=*) "From Fortran ReadFile procedure: n = ", n
         close(UNIT=FileUnit, IOSTAT=Istat)
      end block blk_read
      return
   end subroutine ReadFile
end module m
#include <stdio.h>
#include <string.h>
extern void ReadFile(char*, int*);
int main()
   int n;
   char FileName[9];
   strcpy(FileName, "AMIN.for");
   printf("From C main: FileName = %s\n", FileName);
   ReadFile(FileName, &n);
   printf("From C main: n = %d\n", n);
   getchar();
   return 0;
File AMIN.for:
42
Upon execution with Intel Fortran,
From C main: FileName = AMIN.for
 From Fortran ReadFile procedure: n =  42
From C main: n = 42
Press any key to continue . . .
P.S.> Not sure why, but the forum is giving a problem: the file AMIN.for just has the number 42 in it, but it is not showing up as such.
Muhammad_S_4
Dear all thanks
Firstly thank for your reply
Ok ,so you say there is no setting in VS ?
I try this insted (Steve Lionel (Intel))
      external strlen
      iounit=15
      read (iounit,*) m
      write(*,*) m
      close(iounit)
      return
      end subroutine
Error : forrtl severe (408)
Thanks again
Muhammad_S_4
this is a very very good & exellent and work thank you i want use fortran 77 . is it possible( "bind" in fort77 isn't unkhnown?) and i want find any way to change code in "c-source" without change "fortran-subroutine" for example define any function for pass them . very thanks
mecej4
In #1 you said that you wanted to call from C a Fortran subroutine with a string as argument but without passing the string length argument that Fortran expects and needs in order to compare the lengths of the actual versus the formal arguments. The dyspepsia-inducing solutions of #3 and #4 do what you asked. However, they work only if you build in "release" mode. If you turn argument consistency checking on, as you probably did in #6, they will cause run-time errors and aborts. Your C function requirement
i need to change line  ( is necessary for me):
is it possible? how to call without length character or how to calling convert to run and compile it correctly?
violates the needs of  standard Fortran, so it is self-defeating to ask Fortran to check arguments. In particular, if Fortran looks up and uses a length value that was not passed to it, anything can happen.
Your stipulation that you want a solution in F77 came rather late. With some modifications, the solution of #3 could be made acceptable to a F77 compiler, but one is inclined to ask "Do you really want F77? Why?"
Muhammad_S_4
another question
In c-source , is it possible that define one function to get to it or not?
thanks
