modifying Main Program Code in CVS 2008
Dave_A_1
I would like to modify the Intel Visual Fortran "Main Program Code" in the console template for Intel Composer XE 2013 under VS 2008 and Windows 7.  Is there a way to do this?  Can I also set different attributes, specifically include directories and VMS compatibility, so these are set automatically with each new module creation?
Dave A.
Steven_L_Intel1
You can change the project templates including source and properties - they're in ZIP files under C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE\ProjectTemplates\IntelFortran - but be aware that they'll get overwritten when you update the product. This is not something we support, but it's doable at your own risk.
Dave_A_1
Steve,
Thanks.  Worked like a charm - though I found I had to change the template cache as well as the template ZIP files. (perhaps only had to do the latter, but I had already done the former.)
Dave
