29649 Discussions
modifying Main Program Code in CVS 2008
Dave_A_1
I would like to modify the Intel Visual Fortran "Main Program Code" in the console template for Intel Composer XE 2013 under VS 2008 and Windows 7.  Is there a way to do this?  Can I also set different attributes, specifically include directories and VMS compatibility, so these are set automatically with each new module creation?
Dave A.
You can change the project templates including source and properties - they're in ZIP files under C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE\ProjectTemplates\IntelFortran - but be aware that they'll get overwritten when you update the product. This is not something we support, but it's doable at your own risk.
Dave_A_1
Steve,
Thanks.  Worked like a charm - though I found I had to change the template cache as well as the template ZIP files. (perhaps only had to do the latter, but I had already done the former.)
Dave
