mpif90 problem
mohseng
I keep getting the following message when I try to compile my code by mpif90:
/usr/local/mpich/bin/mpif90: line 332: eval: -c: invalid option
eval: usage: eval [arg ...]
I have included in my fortran code the lines:
include 'mpif.h'
include 'ifortvars.sh'
but it makes no difference. Can someone help me out please?
Mohsen
This is a problem in the mpif90 script, it's not a compiler message.
TimP
The ifortvars.sh script is not intended to be included in your program. You should source it as a shell command, to get the PATH and LD_LIBRARY_PATH set up, before running mpif90. You are likely also to need /usr/local/mpich/bin in the PATH environment variable.
mohseng
MyPATH and LD_LIBRARY_PATH are setup and ifort works. Also I sourced the *.sh file and checked /usr/local/mpich/bin is already in my PATH. Still same message. I guess steve is right and there's something wrong with the mpif90 scripts. But I can't find it.
Any ideas please?
Well, Tim is correct that the include of ifortvars.sh is wrong, but you're not getting that far. The mpif90 script is not even running the compiler. It looks as if there's an eval command on line 332 of the mpif90 script with a syntax error. Either that, or it assumes some version of Linux different from the one you are running. (Linux: A maze of twisty little passages, all different)
mohseng
I set the environment variable
export MPICH_F90=ifort
I guess now it compiles but it makes a *.o file which needs to be linked, as I suppose. The attempt to link mpif90 -o mtest mtest.o or mpif90 -o mtest.f90 mtest.o returns the following message:
/usr/local/mpich/bin/mpif90: line 396: eval: -L: invalid option
I am trying to understand what other env variables I should set.(MPICH_F90LINKER, etc.)
I have attached the mpif90 file. it's not a zipped file.
mohseng
Well I did the same thing for MPICH_F90LINKER
export MPICH_F90LINKER=ifort
and now I get this message:
$mpif90 -echo mtest.f90
+ '[' 0 = 1 ']'
+ allargs= mtest.f90
+ '[' -s mtest.f90 ']'
+ compileargs= mtest.f90
+ linkargs= mtest.f90
+ '[' 0 -lt 2 ']'
+ moduledir=/usr/local/mpich/include/f90choice
+ modulelib=mpichf90
+ '[' -n '' ']'
+ '[' -n '' ']'
+ added_link=0
+ '[' -z '' ']'
+ '[' '!' -r mpif.h ']'
+ status=0
+ '[' 0 = 1 -o 0 = 1 ']'
+ '[' 1 = 1 -o 0 = 1 ']'
+ '[' -z '' ']'
+ LDFLAGS=
+ '[' mpich = mpich ']'
+ mpilibs=-lmpich
+ '[' -n '' -o '!' -s /usr/local/mpich/lib/libpmpich.a ']'
+ '[' yes = yes -a '' '!=' yes ']'
+ proflib=
+ '[' -n '' ']'
+ '[' ignore '!=' ignore -a no = yes -a -s /usr/local/mpich/lib/libmpichfarg.a ']'
+ eval ifort -L/usr/local/mpich/lib mtest.f90 -lmpich
++ ifort -L/usr/local/mpich/lib mtest.f90 -lmpich
fortcom: Severe: No such file or directory
... file is 'mtest.f90'
compilation aborted for mtest.f90 (code 1)
+ status=1
+ '[' 0 = 1 ']'
+ exit 1
I have done the test given in the followingquotation and I think I need to recompile the mpich libraries but I don't know how.
you may be having problems with GNU g77's *INSANE* practice of appending
double underscore suffixes to symbols instead of singles underscores. To
confirm this, do this:
$ nm /usr/local/MPICH/lib/libmpich.a | grep mpi_init
You *should* see something like
0000000000000000 T mpi_init_
However, you may see:
0000000000000000 T mpi_init__
If so, you'll need to recompile your MPICH library using the intel compilers
instead of the GNU compilers. Unfortunately, the Intel compilers do not provide
a flag that will automatically append a second underscore to symbol names (as
other compilers do, like Portland Group).
Randy
Randy Crawford http://www.ruf.rice.edu/~rand rand AT rice DOT edu
Greg LindahlSep 30 2004, 2:14pm show options
Newsgroups: comp.parallel.mpiFrom: lind...@pbm.com (Greg Lindahl) - Find messages by this authorDate: 30 Sep 2004 11:14:58 -0700Local: Thurs, Sep 30 2004 2:14pm Subject: Re: Question on linking MPI programs with ifcReply to Author | Forward | Print | Individual Message | Show original | Report Abuse
In article ...@joe.rice.edu>, Randy ...@burgershack.com> wrote:
>Or you may be having problems with GNU g77's *INSANE* practice of appending
You could argue that the insane practice of ignoring the platform
de-facto ABI (AND not providing a switch for compatibility) is worse
than the g2c style of mangling, but I digress. BTW, the actual g2c
algorithm appends one _ to symbols without any _'s.
-- greg
andreyOct 1 2004, 6:30am show options
Newsgroups: comp.parallel.mpiFrom: andrey ...@physics.susu.ac.ru> - Find messages by this authorDate: Fri, 01 Oct 2004 16:30:02 +0600Local: Fri, Oct 1 2004 6:30am Subject: Re: Question on linking MPI programs with ifcReply to Author | Forward | Print | Individual Message | Show original | Report Abuse
Thanks a lot!
It was because of the second underscore in the MPI libraries. I
recompiled them using switch -fc=ifc, and everything is ok now with
compiling and linking :)
Andrey
Yes, the Intel compiler does provide such an option to append an underscore. In fact, there are two of them, to compensate for g77's strangeness:
[no]underscore Determines whether the compiler appends an underscore character to external user-defined names.
[no]2underscores
Determines whether the compiler appends two underscore characters to external user-defined names.
(The actual implementation is the same as g77s, where two underscores are appended if the name contains an underscore - I think.. This particular issue always makes my head spin...)
