mspdb80.dll, incorrect version
greg_rowe
I'm trying the evaluation version of the Visual Fortran Compiler but whenever I try to compile a project I get a "Fatal Error LNK1101: incorrect mspdb80.dll version" error. I did a quick check, I found 4 copies of this dll on my machine all with a version number of 9.0.30729.01, can someone tell me which version I should be using so I can actually evaluate this product.
Cheers,
Greg.
greg_rowe
Forgot to say I'm using version 11.0.074 version for IA-32 and Intel-64.
Cheers.
TimP
If the search button on this forum is working, it might turn up some information on this subject. I suspect you might not have Visual Studio service packs correctly installed. Visual Studio installations have been known to break to the point where it is necessary to start over; download the original VS (if you don't have a DVD), as well as service packs, and re-install Intel compilers. They do this intentionally if you have a beta service pack, you must remove VS service packs and start over with release service packs.
