multi-file optimization compilation error
pauline_weywada
I'm trying to build a solution with Intel Visual Fortran and I receive the following linking error:
Link: error #10014: problem during multi-file optimization compilation (code -1073741819)
I'm using a windows 7 64 bits machine, Intel processor.
When I turn off the optimization process by typing /qnoipo in the command line of the linker I still have this error, and when I select 'no' in the interprocedural optimization there is also an error because it puts the /qnoipo command in the middle of the list of commands.
Can you help me please?
If you need more information let me know.
Pauline.
TimP
The ipo link time message usually is a consequence of an earlier error, so by itself this message is useless.
Do you mean option /Qipo- ? This option will turn off IPO when making .obj files, but the linker will still perform a search for IPO objects. There isn't a straightforward way to prevent that. If you do prevent the IPO linker from running, the link will fail if there were IPO objects.
CFM
I have the same error message: "5>Link: error #10014: problem during multi-file optimization compilation (code 128)2
I am using Compiler XE : Intel(R) Visual Fortran Compiler XE on IA-32, version 12.1.2 Package ID: w_fcompxe_2011.8.278
Note that in Debug mode all work fine.
I tried all options in IPO...
Francis
Steven_L_Intel1
TimP's response usually applies - look to see if there was an error from earlier build steps.  If you need further help, we'd need to see a ZIP of the project.
