29652 Discussions
multiple executions from batch without screen halting
Deleted_U_Intel
When attempting to run a model from a batch file multiple times, the batch file (run from a DOS window) halts because when the application completes one execution cycle the screen message "Program Terminated with exit code 0. Exit Window?" appears. How can this be avoided?
John
jimdempseyatthecove
In your batch file where you have
YourProgramNameHere arg1 arg2
Try
START /WAIT YourProgramNameHere arg1 arg2
Use START /? to get options
You also may need to look at
START /WAIT CMD /C YourProgramNameHere arg1 arg2
Jim Dempsey
anthonyrichards
New Contributor III
Start your program with a CALL to a batchfile that starts your program? Make sure you do not specify an exit code using STOP exitcode or CALL EXIT(exitcode) in your program?
onkelhotte
New Contributor II
John
lret = SetExitQQ (QWin$ExitNoPersist)
avoids the Program Terminated message in a QuickWin application.
Markus
