Can I get help with use of the s_hbc_sparse features of IMSL on this forum? Or should I go to roguewave forums?
I want to know if it is possible to do an LU factor, followed by many linear equation solves, with a sparse matrix using the s_hbc_sparse derived type and overloaded operators.
Brian in Austin, Texas
There are some experienced IMSL users here, but I would recommend asking in the Rogue Wave forums.
I posted at Roguewave last week. So far no replies. I gotta believe that if they call it SuperLU, it ought to be able to do what I want. Isn't that what LU factoring is all about? I suppose I'll have to make test program and take a stab at it. I'll just be guessing as to how to get the LU to be saved. I don't see anything in the IMSL documentation about that.
Brian
Let me forward your question to my counterparts at RW and see what they say.
Ok, got an answer:
Yes, he is correct. For the sparse operator using SuperLU, the LU factorization is done on the first “call” to .ix. and saved for any subsequent calls for the same s_hbc_sparse definition.
Thanks, Steve. I am preparing code right now that will try this. It's in the iteration loop of an Arnoldi eigensolver.
Cheers,
Brian
