When a multi-loop process takes long time, I would like to have the loop number shown on the monitor. And I prefer having the loop number appear at the same spot so that other information is not rolled up.
I wrote a test program as follows:
program noAdvanc
use IFPort
integer loop
do loop = 1, 5
write(6,11) char(13), loop
11 format($,a,i5)
call sleep(1)
end do
end program noAdvanc
This program does what I wold like to see. But F95 does not allow the edit descriptor ($,a,i5).
If I have two of those statements replaced by
write(6,11,advanmce=no) char(13), loop
11 format(a,i5)
The monitor does not show 1, 2, 3, and 4 before showing the last number 5.
What is the way, which meets the F95 standard, to do it?
Wen
Thank you.
Wen
By the way, I just clicked on "Quick Reply" and there was no responce.
Try reworking the routine using PUTC.
Jim Dempsey
QuickReply opens a popup window - if your browser blocks those, you wouldn't see it.
