This non-commerical license works on my laptop but not a server. I get the following message. How can I fix this? The licenses are in the places it claims to be searching.
David
Error: A license for FComp is not available (-5,357).
Make sure that a license file is being used that contains a license
for the requested feature. If your license requires a license server,
make sure that the server is using the right license file (usually,
this would be the same license file that is being used by this
application), and make sure that you have not changed the license
file since starting the server.
License file(s) used were (in this order):
1. /usr/local/Intel/licenses/l_cpp_41393686.lic
2. /usr/local/Intel/licenses/l_for_11286620.lic
3. /usr/local/pgi/license.dat
Please visit http://support.intel.com/support/performancetools/support.htm if you require technical assistance.
ifc: error: could not checkout FLEXlm license
David
I'd suggest following the "Please visit..." instructions in the error message.
Steve
Steve
Thank you.
David
David
