29652 Discussions
*.o: file not recognized: File format not recognized
pridam
I am using intel fortran 10.1.013.
Production of my *.o files is successfull.
But now, I am blocked at the generation of my shared library :
Command line: ifort -shared *.o -o libmylib.so
It returns the following error: *.o: file not recognized: File format not recognized
I am working on a 32 bits Linux RedHat 5.
But when I do a ifort -logo, it returns : Intel Fortran Compiler for applications running on Intel 64
Is the installation of fortran incorrect ? What can I do ?
Thanks for your answers
Priscilla
Kevin_D_Intel
The command line shown is correct so that's not an issue.
The error is actually emitted by the linker and not the compiler and it relates to using a 64-bit capable compiler with a 32-bit capable linker.
First, ensure the 32-bit Intel Fortran compiler is installed. The 64-bit compiler installs under /opt/intel/fce. The 32-bit compiler installs under /opt/intel/fc. (Note the absence of "e" in the 32-bit case).
When setting up your environment to use the compiler, you need to execute:
source /opt/intel/fc/10.1.013/bin/ifortvars.sh (or.csh)
Since your using the 64-bit compiler, that says you source'd the ifortvars.sh (or .csh) from the "fce" area.
Hope that helps.
