29429 Discussions
/o3 delivers in x64 only bad performance
Johannes_Rieke
New Contributor III
Hi all,
In a simple ASCII-file read subroutine I observed a strange performance loss behavior only in x64 release mode but not in x64 debug, Win32 debug and Win32 release mode. In every release case I use /o3 (ifort 15.0.0.108), in debug optimization is turned off. The release reading performance in the latter three cases is nearly the same. The ASCII file contains x, y, z coordinates of a grid (1025 lines). Commenting the preprocessor commands and the screen output makes no difference.
But, if I use /o2 for this subroutine the performance is the same as for the three other cases, reading the files takes now 1 second instead of 12 seconds. Is it possible to find the reason for this behavior with only the information from the code snipped? In /o3 the vectorrization report shows the lopps do i.. and d j .. are vectorized. In /o2 they are not. In Win32 /o3 there are also vectorized, but no performance issue is seen. (r3grid is a double precision real array).
Any hint is welcome, Johannes
[fortran]
  ie = len_trim(t0grid)
  inquire(file=t0grid(1:ie), exist=l0in)
  if (l0in) then
    open(i0ugrid,file=t0grid(1:ie),status='old',buffered='YES',action='read')
  else
    write(*,9900) t0grid(1:ie)
    pause
    stop
  end if
! *** read the mesh
  read(i0ugrid,'(a)') t0dumy ! skip header
  read(i0ugrid,*) t0circ,i0schnitte,t0profil,i0profilpunkte,t0dim,i0dim
  allocate(r3grid(i0schnitte,i0profilpunkte,i0dim))
  write(t0s,'(i4)') i0schnitte
  write(t0p,'(i4)') i0profilpunkte
  write(t0d,'(i4)') i0dim
  call write_both( '     - Read GRID with '//t0s//       &
 &                 ' sections and '//t0p//' nodes in ' &
 &                 //t0d//' dimensions')
#if defined(_WIN32) || defined(_WIN64)
  open(6,carriagecontrol ='fortran')
#endif
  do i = 1, i0schnitte
    do j = 1, i0profilpunkte
      read(i0ugrid,*) r3grid(i,j,1:i0dim)
    end do
    write(6,'("+       Progress: ",i4," von ",i4," Sections read.")') i,i0schnitte
#endif
  end do
  open(6,carriagecontrol ='list')
#endif
[/fortran]
