29650 Discussions
omitting brackets while calling type-bound procedure
holgerwolff
Hello
I made a simple error while familiarising myself with some Fortran 2003 features. However, the output of the Fortran compiler tells me that it encountered a catastrophic failure, and asked me to let you know. So here it is:
example code:
[fortran]module errormod
  implicit none
  type :: errortype
    real, private :: value
  contains
    procedure, public :: set => set_value
    procedure, public :: get => get_value
  end type
  private :: set_value, get_value
contains
  subroutine set_value( self, v )
    implicit none
    class(errortype)  :: self
    real, intent(in)  :: v
    self % value = v
  end subroutine set_value
  function get_value( self )
    implicit none
    real              :: get_value
    get_value = self % value
    return
  end function
end module errormod
program error
  use errormod
  implicit none
  type(errortype) :: e
  call e % set ( 1.0 )
  ! This fails to compile with a catastrophic error
  write (*, *) e % get
  ! This works
! write (*, *) e % get()
end program error
[/fortran]
When compiling, I get this error:
[bash]$ ifort -o error error.f90
error.f90(41): catastrophic error: **Internal compiler error: internal abort**
Please report this error along with the circumstances in which it occurred in a
Software Problem Report. Note: File and line given may not be explicit cause of this error. write (*, *) e % get ---------------^ compilation aborted for error.f90 (code 3) [/bash]
I don't know how to fill out a Software Problem Report, so I am posting this here.
And here some info about my system:
[bash]$ ifort --version
ifort (IFORT) 11.1 20091130
Copyright (C) 1985-2009 Intel Corporation.  All rights reserved.
$ uname -a
Linux xxxxxxx 2.6.32-24-generic #39-Ubuntu SMP Wed Jul 28 06:07:29 UTC 2010 i686 GNU/Linux[/bash]
Since I know where the error is in my code, and can correct it, I don't need an answer. So if this problem has been fixed, I'm happy for you to close and/or delete this thread.
mecej4
This compiler error does not occur with version 11.1.072, which gives the syntax error:
"ibug1.f90(41): error #8319: An EXTERNAL procedure name must not appear in an input/output item list. [GET]"
Ron_Green
We leave these threads in the forum in case others see the same issue.
Type bound procedures are one of the Fortran 2003 features we've been working on in 11.1 and the next version of the compiler.
ron
Lester
Since putting parentheses after the get not only removes the error message from both versions of the compiler, but the resulting executable runs and give the correct answer, the 11.1.072 error message probably isn't right either.
mecej4
Section 12.4, rule R1217 of the Fortran Standard (J3/04-007) shows the parentheses as mandatory for a function reference. The message could have said "...missing argument list and parentheses...".
Since a single syntax error may cause violations of more than one language syntax rule, it is difficult to pick in advance the best wording of the error message.
Ron_Green
Let me ask our front-end team how easy/difficult it would be to improve the error message here. It would be nice to have a better message.
Simplified:
module errormod
implicit none
type :: errortype
contains
end type
private :: get_value
contains
implicit none
real :: get_value
return
end function
end module errormod
program error
use errormod
implicit none
! This is a user bug, forgot () after e%get()
! correct is: write(*,*) e % get()
end program error
Ron_Green
We improved the error message in the Composer XE 2011 ( aka v12.0 ) compiler:
$ ifort reprou76793.F90
reprou76793.F90(31): error #8497: Illegal use of a procedure name in an expression, possibly a function call missing parenthesis. [GET]
$ ifort reprou76793.F90reprou76793.F90(31): error #8497: Illegal use of a procedure name in an expression, possibly a function call missing parenthesis. [GET]write (*, *) e % get-------------------^
