one error in run time
raulepuebla
I compiled a code for f90 with ifort and when I run the program, it crashed with the following error:
Error in SET_VAR_RAD_MOD
Unable to allocate required memory
IOS= 41
Someone there knows what do this mean? and how can I fix it?
Thank you.
rau.
That error comes from your program. Search its source for that text to see where it came from. However, the error in general is that the program tried to allocate more virtual memory than was available. There are many possible causes for this, some that can be fixed in the code, some that can't.
