oneAPI HPC Toolkit 2024
JSanz
Hello, I am a standard user without priority support. I urgently need to download the offline installer for Intel oneAPI HPC Toolkit 2024.2 for Windows, because I’ve switched to a new PC and my legacy project depends on the classic ifort compiler, which is now obsolete. Could an administrator please provide me with a temporary direct link to w_HPCKit_p_2024.2.1 offline for Windows? Thank you.
andrew_4619
That is  not available to download unless you have priority support, Why does your program depend on IFORT, must you build 32bit?
JohnNichols
Honored Contributor I
You will have to take your legacy code to 64 bit eventually, may as well start now.
We have all had this problem.
masonreed11
If Intel no longer lists that installer publicly, your best option is to ask an Intel moderator or administrator directly, as they sometimes can provide temporary access to older packages if they're still available. It also helps to explain that your project specifically depends on the classic ifort compiler and that you're migrating to a new PC.
andrew_4619
No that does not happen, if you have paid support the download can be available  from the download centre, IFORT is not on the free Oneapi downloads pages. end of.
