oneapi 2002.2
JohnNichols
Honored Contributor I
The equivalent of this screen does not show up on the 2022.2 base and hpc install instead the programs exit. The app location tells you oneapi base and hpc are installed, but you have to restart the install and select modify and then fix them.
Is this normal?
I know they are not installing as the install time for VS integration is several minutes and the packages stop after 10 seconds.
Devorah_H_Intel
Do you have an install log from failed installation?
JohnNichols
The second install did not work and the third took more than an 0.75 hours at 97%.  It works it appears on 2019 but not 2022.
Where do I find the logs, I will do it again on a nuc and see if I can repeat the errors and send you the logs.
Did you see the compiler error that I reported in another thread?
JohnNichols
Found logs.  This is all of them.
The error is in the machine learning post.
JohnNichols
ifx is not in VS
