						I am using the following code foropen file dialog. it works in CVF , but get some error for GETOPENFILENAME. How can I make this work in IVF?
Thanks so much,
Lu
!codes written in CVF
USE DATA_SET
USE DFLIB
USE DFWINTY
USE DFWIN
IMPLICIT NONE
TYPE (T_OPENFILENAME)FRED
LOGICAL(KIND=4)RET
INTEGER(KIND=4)ilen1,ilen,ierror
! character(8) dataset
CHARACTER(LEN=60)DLGTITLE
CHARACTER(LEN=256):: file_spec=" "C
!CHARACTER*(*), PARAMETER::FILTER = &
!"Data Files(*.data)"C//"*.data" C// &
!"All Files(*.*)"C//"*.*" C//" "C
'Data Files(*.data)' //char(0)//'*.data' //char(0)// &
'All Files(*.*)' //char(0)//'*.*' //char(0)//char(0)
LOGICAL(KIND=4)CHECKED
DLGTITLE = 'Input Program Data Files'C
FRED%LSTRUCTSIZE = (BIT_SIZE(FRED%LSTRUCTSIZE) + &
BIT_SIZE(FRED%HWNDOWNER) + &
BIT_SIZE(FRED%HINSTANCE) + &
BIT_SIZE(FRED%LPSTRFILTER) + &
BIT_SIZE(FRED%LPSTRCUSTOMFILTER) + &
BIT_SIZE(FRED%NMAXCUSTFILTER) + &
BIT_SIZE(FRED%NFILTERINDEX) + &
BIT_SIZE(FRED%LPSTRFILE) + &
BIT_SIZE(FRED%NMAXFILE) + &
BIT_SIZE(FRED%LPSTRFILETITLE) + &
BIT_SIZE(FRED%NMAXFILETITLE) + &
BIT_SIZE(FRED%LPSTRINITIALDIR) + &
BIT_SIZE(FRED%LPSTRTITLE) + &
BIT_SIZE(FRED%FLAGS) + &
BIT_SIZE(FRED%NFILEOFFSET) + &
BIT_SIZE(FRED%NFILEEXTENSION) + &
BIT_SIZE(FRED%LPSTRDEFEXT) + &
BIT_SIZE(FRED%LCUSTDATA) + &
BIT_SIZE(FRED%LPFNHOOK) + &
BIT_SIZE(FRED%LPTEMPLATENAME))/8
FRED%HWNDOWNER = NULL
FRED%HINSTANCE = NULL
FRED%LPSTRFILTER = LOC(FILTER)
FRED%LPSTRCUSTOMFILTER = NULL
FRED%NMAXCUSTFILTER = 0
FRED%NFILTERINDEX = 1
FRED%LPSTRFILE = LOC(file_spec)
FRED%NMAXFILE = LEN(file_spec)
FRED%LPSTRFILETITLE = NULL
FRED%NMAXFILETITLE = 0
FRED%LPSTRINITIALDIR = NULL
FRED%LPSTRTITLE = LOC(DLGTITLE)
FRED%FLAGS = NULL
FRED%NFILEOFFSET = NULL
FRED%NFILEEXTENSION = NULL
FRED%LPSTRDEFEXT = LOC("data"C)
FRED%LCUSTDATA = NULL
FRED%LPFNHOOK = NULL
FRED%LPTEMPLATENAME = NULL
RET = GETOPENFILENAME(FRED)
CALL COMDLGER(IERROR)
IF(.NOT.RET) THEN
PRINT *,' No new file name specified'
else
end if
RETURN
END
Thanks so much,
Lu
USE DATA_SET
USE DFLIB
USE DFWINTY
USE DFWIN
IMPLICIT NONE
LOGICAL(KIND=4)RET
FRED%FLAGS = NULL
IF(.NOT.RET) THEN
else
end if
RETURN
END
						The error message isinvalid lStructSize error
						FRED%LSTRUCTSIZE = SIZEOF(FRED)
						How does your code fail in IVF?
What is the result of COMDLGERROR?
Try
CHARACTER(18)::FILTER(5)
! Make all FILTER strings the same length
FILTER(1)='Data Files(*.data)'C
FILTER(2)=' *.data' C
FILTER(3)='All Files (*.*)'C
FILTER(4)=' *.*'C
FILTER(5)=char(0)//char(0)
FRED%LPSTRFILTER= LOC(FILTER(1))
FRED%LSTRUCTSIZE= SIZEOF(FRED)
Try
FILTER(4)=' *.*'C
						Dear Paul,
Thanks so much for you reply. I can not reach my computer until Wednesday. I will try this and keep you updted the results.
Lu
Lu
						Dear
Dear Paul,
It works! Thanks so much!
Lu
						Dear anthonyrichards,
Thanks again for your answer.This works and isvery helpful to me!
Lu
Lu
			Topic Options
