29386 Discussions
opposite change between 'Debug' and 'Release' in program efficiency of time consuming
jackmwl
Hi everyone
I have been trying to improve the program efficiency in time and memory andmake tradeoff between them. CPUTIME is used to measure the time consuming, but efficiency in memory isevaluated by experience. The effortswere focused on the procedure which would be called ten thounds times when executing the program.
The original codes are shown as follows,
REAL(8), INTENT(IN) :: x(n)
REAL(8), DIMENSION(:), ALLOCATABLE :: YYDM, RetL, RetR...
REAL(8), DIMENSION(:,:), ALLOCATABLE :: YYD, YYA, UU...
ALLOCATE(...)
! assign subsection of x to YYD, YYA, UU...
! operations on YYD(:,j), YYA(:,j), ...,YYDM,RetL,RetR...
DEALLOCATE(...)
The improved codes are
TYPE :: opter
REAL(8), DIMENSION(Nd) :: YY
REAL(8), DIMENSION(Nu) :: UU
REAL(8), DIMENSION(Nd) :: Ret
END TYPE opter
TYPE (opter) :: optmid
TYPE (opter), TARGET :: optlft, optrgt
TYPE (opter), POINTER :: prtlft, prtrgt, prttmp
NULLIFY(prttmp)
prtlft => optlft
prtrgt => optrgt
DO ...
! assign subsection of x to prtlft,prtrgt,optmid
! operations on prtlft,prtrgt,optmid
prttmp => prtlft
prtlft => prtrgt
prtrgt => prttmp
END DO
NULLIFY(prtlft, prtrgt, prttmp)
The original and improved program cost 50 seconds and 35 seconds in 'Debug', respectively. However,they cost7.5 seconds and 8.0 seconds in 'Release'.So why the improved program costs less time in 'Debug' but more time in 'Release' than the original?
Any help would be highly appreciated!
Best regards
Jack
jimdempseyatthecove
Jack,
It would appear that the compiler opmizations works better on your original code than it does on your "improved" code. IOW your improvements at self optimizations hinder the compiler from fully optimizing your code. Without your code listed it would be hard to guess as to what is going on. One thing to look for is enable/check diagnostic reports to see if your improvements hinder vectorization.
Jim Dempsey
jackmwl
Hi Jim,
Thanks for your quick reply!
The original and "improved" code have been attached here.
By the way, what should i do to enable/check diagnostic reports to see if the improvements hinder vectorization?
Best regards
Jack
jimdempseyatthecove
After a quick look (no analysis)...
Your "improved" code is copying data into user defined types (e.g. optmid)whereas the old code is simply remembering the index of where the selected (found) data resided in the original input array (e.g. YYAMID)
I think you are unnecessarily moving data about as opposed to remembering where it resided.
Jim Dempsey
jackmwl
Hi Jim,
Thanks for your advice.
I will test the way remembering where it resided.
Best regards
Jack
