optimization and parameters
tracyx
I often use parameters to enable or disable parts of my code. I want to make sure that I am doing it the most efficient way. e.g. if I have.
integer, parameter :: dosomething = 0
print *, y+dosomething*somefunction(x)
then would the compiler internally completely remove dosomething*somefunction(x) so treating it just the same as if I had just written print *, y? How, if at all, does this behaviour depend on the optimization settings? Would it be better to use conditional statements?
thank you for your time
TimP
If somefunction were declared PURE, in principle, the compiler could do this. I doubt that it is sufficiently common practice for a compiler to be designed with this in mind.
logical, parameter :: dosomething = .false.
print *, merge(y+somefunction(x),y,dosomething)
for example, looks more direct to me, but would not solve the problem.
tracyx
Thanks. I tried a simple piece of code:
program test
implicit none
real(8), external :: somefunction
integer :: i
do i = 0, 5
print *, 5.0_8 + dosomething*somefunction(i)
end do
end program
function somefunction(x)
implicit none
integer, intent(in) :: x
real(8) :: somefunction
somefunction = 1.0_8/dble(x)
end function
Now, if I compile this without any optimizations (O0), then the first thing that is printed is NAN since we have zero times infinity so the compiler is clearly not removing it. If I compile it with higher level optimizations, then it just prints 5 so it looks like the compiler is completely removing the code in that case. Moreover, if I compare the binary files with optimizations, then they are identical regardless of whether I have dosomething=0 or whether dosomething*somefunction(i) is commented out. Does anyone know if the compiler will always do this?
"always" is perhaps a bit too strong. The compiler does some interprocedural optimization by default at level O2 or higher and in cases where it can see that a computation is not required, it may remove it or evaluate it at compile time.
