outlining issue
abhimodak
Hi
Perhaps this has already been reported --
I find that since outlining is continuosly "listening" quite often there is an irritating situation... You ask for all regions collapsed by (using Right click and collapse to definitions). Then you go the line where you want to start editing. Type, say do hit enter and type end do. Everything in that file below these lines will have regions expanded..Sometimes even some of the things above this are also expanded....Is there any automatic way for this not happen?
Abhi
I was finally able to reproduce this - it doesn't do it to me for every source. I escalated it to the developers as issue DPD200182137. Other than turning off outlining, I don't have a workaround for you.
