29650 Discussions
parameterised derived type default kind parameters
Nicholas_B_
Parameterised derived types with kind parameters which have default values set to parameters are not working as I expect in Intel Visual Fortran Compiler XE 15.0.2.179. Is this a bug or are my expectations wrong?
The following code shows the issue:
module imp_module
  implicit none
  private
  integer, parameter :: n = 5
  type, public :: dt(k)
     integer, kind :: k = n
     integer, dimension(k) :: x
  end type dt
end module imp_module
program imp_prog
  use imp_module
  type(dt) :: x
  print *,x
end program imp_prog
Compiling the code gives:
Deleting intermediate files and output files for project 'imp', configuration 'Debug|Win32'.
Compiling with Intel(R) Visual Fortran Compiler XE 15.0.2.179 [IA-32]...
ifort /nologo /debug:full /Od /warn:interfaces /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc120.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qvc12 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\\bin" "C:\Users\Nicholas\Documents\imp_bug\imp_module.f90"
ifort /nologo /debug:full /Od /warn:interfaces /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc120.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qvc12 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\\bin" "C:\Users\Nicholas\Documents\imp_bug\imp_prog.f90"
C:\Users\Nicholas\Documents\imp_bug\imp_prog.f90(5): error #6683: A kind type parameter must be a compile-time constant.
  type(dt) :: x
compilation aborted for C:\Users\Nicholas\Documents\imp_bug\imp_prog.f90 (code 1)
imp - 2 error(s), 0 warning(s)
Regarding Ian's examples in post 19, I tried them with the current in-house compiler. The first one gets a compile-time error, but not a correct one. The second still has the same bad behavior. The third now gives no standards warnings. I have reported the first two to the developers.
The problem Nicholas described in the original post has been fixed for a release later this year. The issues from Ian's post #19 are still being investigated.
The issues Ian raised in post 19 are being fixed for the 16.0 release.
