29389 Discussions
passing arguments to *.exe file from command prompt
ritesh_agrawal
hello
I have a fortran code and and its executable file. I am using java to run the executable file. Now my problem is to pass some variables from java to exe file. Is there any way I can do it.
One possible way was to write the values in a file and read that file but this is not possible in given circumstance so I am looking for another option.
The other option I am trying to explore is like passing the string from java containing the exe file name and arguments as given below
icfm.exe -I infile.txt -O outfile.txt
Now I have to write a fortran code that can read this line from commnad prompt and take input from infile.txt and write final results to outfile.txt
Thanks in advance
Ritesh Agrawal
rahzan
Is GETARG not working for some reason?
Tim
ps,
I have actually done this way back in the jurassic w java 1.0beta and MSPS4!
