passing pointer to a subroutine fails
Ekaterina_M_
Dear all,
I am facing an issue with passing a pointer to a subroutine. Here is a simplified version of my code:
      program test_ptr
      interface
      subroutine sub(iptr)
      dimension iptr(5)
      end subroutine sub
      end interface
      save
      integer, dimension(:), pointer :: iptr
      allocate(iptr(5))
      iptr = 0
      call sub(iptr)
      deallocate(iptr)
      end
c      dimension iptr(5)
      end
If I declare iptr allocatable in the subroutine (commented line), everything goes fine. However I want iptr be a pointer in the subroutine, and in this case my code fails on a memory fault at the moment it enters the subroutine.
The attached code does not fail (must be too simple for that) but valgrind complains about invalid reads.
I have compiled with gfortran and passed through valgrind the same code, and there were no issues at all (except that gfortran insisted I add an interface block).
My compile/run instructions and output follow:
> ifort -g -O0 test_pointer.F; valgrind --leak-check=full --show-reachable=yes ./a.out
==18156== Memcheck, a memory error detector
==18156== Copyright (C) 2002-2012, and GNU GPL'd, by Julian Seward et al.
==18156== Using Valgrind-3.8.1 and LibVEX; rerun with -h for copyright info
==18156== Command: ./a.out
==18156==
==18156== Invalid read of size 8
==18156==    at 0x403256: sub_ (test_pointer.F:23)
==18156==    by 0x403095: MAIN__ (test_pointer.F:16)
==18156==    by 0x402E7D: main (in /home/emakarov/FlowSimulator/test_pointer/a.out)
==18156==  Address 0x5c1f120 is not stack'd, malloc'd or (recently) free'd
==18156==
==18156==    at 0x403259: sub_ (test_pointer.F:23)
==18156==  Address 0x5c1f130 is not stack'd, malloc'd or (recently) free'd
==18156==
==18156==
==18156== HEAP SUMMARY:
==18156==     in use at exit: 32 bytes in 1 blocks
==18156==   total heap usage: 3 allocs, 2 frees, 68 bytes allocated
==18156==
==18156== 32 bytes in 1 blocks are still reachable in loss record 1 of 1
==18156==    at 0x4C26E77: calloc (vg_replace_malloc.c:593)
==18156==    by 0x5A1C53F: _dlerror_run (in /lib64/libdl-2.11.2.so)
==18156==    by 0x5A1C0A9: dlsym (in /lib64/libdl-2.11.2.so)
==18156==    by 0x40D90E: for__aio_init (in /home/emakarov/FlowSimulator/test_pointer/a.out)
==18156==    by 0x405C29: for_rtl_init_ (in /home/emakarov/FlowSimulator/test_pointer/a.out)
==18156==    by 0x402E78: main (in /home/emakarov/FlowSimulator/test_pointer/a.out)
==18156==
==18156== LEAK SUMMARY:
==18156==    definitely lost: 0 bytes in 0 blocks
==18156==    indirectly lost: 0 bytes in 0 blocks
==18156==      possibly lost: 0 bytes in 0 blocks
==18156==    still reachable: 32 bytes in 1 blocks
==18156==         suppressed: 0 bytes in 0 blocks
==18156==
==18156== For counts of detected and suppressed errors, rerun with: -v
==18156== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 2 from 2)
> gfortran -g -O0 test_pointer.F; valgrind --leak-check=full --show-reachable=yes ./a.out
==18171== Memcheck, a memory error detector
==18171== Copyright (C) 2002-2012, and GNU GPL'd, by Julian Seward et al.
==18171== Using Valgrind-3.8.1 and LibVEX; rerun with -h for copyright info
==18171== Command: ./a.out
==18171==
==18171==
==18171== HEAP SUMMARY:
==18171==     in use at exit: 0 bytes in 0 blocks
==18171==   total heap usage: 22 allocs, 22 frees, 12,091 bytes allocated
==18171==
==18171== All heap blocks were freed -- no leaks are possible
==18171==
==18171== For counts of detected and suppressed errors, rerun with: -v
==18171== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 2 from 2)
I would appreciate any help with this issue.
Ekaterina.
mecej4
The subroutine you have is of such a nature that the Fortran standards require you to provide an explicit interface to it in subprograms that contain a call to the subroutine. You provided an interface with an interface block, but the interface block does not match the declaration of the function. In effect, you deceived the compiler. If you recompile with the option "-warn interfaces", the compiler will tell you about the incorrect interface.
You mention "attached code", but I see no attachments. If you change Line-5 of the code insert to match Line-25, the code compiles and runs fine.
Ekaterina_M_
Thanks a lot mecej4!
The "attached code" was in fact the one I cited.
You are totally right about the interface mismatch, I have tried so many different combinations (in the beginning, I had interface block at all) that I went to this error and I didn't notice it.
The problem is resolved now.
FortranFan
You may want to look into using modules and submodules (a Fortran 2008 feature recently introduced in Intel Fortran 16.0 beta version) and the benefits they bring, especially with providing explicit interfaces and structuring code - see Dr Fortran blog.  Can you replace your external procedures with module procedures as shown below with your example?
module m
   implicit none
   private
   public :: sub
contains
      !      dimension iptr(5)
   end
end module m
program test_ptr
   use m, only : sub
   save
   allocate(iptr(5))
   iptr = 0
   call sub(iptr)
   deallocate(iptr)
end
Ekaterina_M_
Thank you, FortranFan!
