path to MKL include
abhimodak
Hi
In IVF 11.1.060, I see from Tools-->Options-->IVF-->Compilers-->Include the path to mkl modules is still missing \\platform. (I believe Steve had already reported this in Nov. 2009). I had uninstalled all previous versions before installing the latest update and I don't recall changing the include path before.
Am I missing something or is it due to some error (although I did not see it) during the installation?
If indeed it is still missing, I would think that when IVF install does it in a future update, the default for em64t will most likely be \\em64t\\lp64. (As I understand, ilp64 is to be used for huge arrays and/or when using /i8 compiler switch.)
Abhi
Given that there are now two different sets one might use, I'm not sure how this should be handled. But clearly the current default is ALWAYS wrong. I will check on that.
abhimodak
Stating the obvious: I notice that the fortran environment from command line (programs --> IVF compiler --> Fortran Build Enviroment) is also missing the \platform.
Abhi
This should be fixed in the next major release.
