I see in intel fortran and elsewhere that a pointer cannot be specified in a NAMELIST statement; however, when I do so anyway, no compiler errors occur. Furthermore, it seems to work just fine in that reading the namelist file updates the pointer and associated target as expected.
Given that it is not supposed to work, I won't use it, but why does it work at all (or have I misread something)?
cheers,
-joe
where test.data is:
cheers,
-joe
[fortran]module glob
implicit none
integer, parameter:: n = 10
real(8), target:: x(n)
real(8), pointer:: ptox1, ptox2
namelist /test/ x, ptox1
contains
subroutine initialize ()
ptox1 => x(1)
ptox2 => x(2)
return
end subroutine initialize
end module glob
program pointertests
use glob
implicit none
call initialize ()
open(unit=1,file='test.dat',status='old')
read(1,nml=test)
close(unit=1)
write(6,*) 'x: ', x(1:2)
write(6,*) 'ptox1: ', ptox1
write(6,*) 'ptox2: ', ptox2
stop
end program pointertests[/fortran] where test.data is:
[plain]&test x(1:2) = 1.0, 2.0 ptox1 = 10. /[/plain]
This is legal in Fortran 2003. If you ask for F90 or F95 standards checking, it will complain.
