29382 Discussions
pointers as arguments - woe is me (Intel Fortran 10.0, Linux, x64)
fattyboomsticks
Allocating an array within a subroutine and then associating a pointer argument (of the subroutine) to the array is giving unexpected results. Upon leaving the subroutine, the pointer is associated but the memory that it should be pointing to appears to have been deallocated.
A simple example. Suppose the subroutine test1 resides in a MODULE somehwere:-
SUBROUTINE test1(array1)
INTEGER, DIMENSION(:), POINTER :: array1
INTEGER, DIMENSION(:), ALLOCATABLE, TARGET :: test_array
INTEGER i
ALLOCATE(test_array(1:2))
DO i = 1, 2
test_array(i) = i
END DO
array=>test_array
DO i = 1, 2
PRINT *, array1(i) !This gives the expected result i.e. "1, 2"
END DO
END SUBROUTINE test1
Now try calling test1() in the program main, as follows:
PROGRAM test
USE test_module !Contains test1()
IMPLICIT NONE
INTEGER i
CALL test1(array1 = array)
IF(ASSOCIATED(array)) THEN
PRINT *, "ASSOCIATED" !Prints 'ASSOCIATED', as expected...
ELSE
PRINT *, "UNASSOCIATED"
END IF
DO i = 1, 2
PRINT *, array(i) !...however this prints seemingly random values!
END DO
END PROGRAM test
Is there some catch about using a pointer argument that I have missed?
Thanks for any help!
TimP
Automatic deallocation is required by the f95 and 03 standards, when leaving the subroutine where ALLOCATE is executed. Prior to that, the situation was undefined.
fattyboomsticks
Thanks for your prompt response.
jimdempseyatthecove
You could perform the allocation on the pointer
allocate(array1(n))
Then it will persist through the return
Jim Dempsey
You want to put the SAVE attribute on the ALLOCATABLE array. This will preserve its value when the routine exits. You may want to add an IF (ALLOCATED()) test in the routine to make sure you don't accidentally reallocate it.
