29386 Discussions
possible bug with !DIR$ directive and option /stand:f08
johnyb_
Take the following code:
subroutine test
	!DIR$ ATTRIBUTES DLLEXPORT :: test
    print *,"if this line exceeds 132 characters, the directive makes the compilation fail if using /stand:f08                                 1"
end subroutine
if I compile it with
ifort sub.f90 /c
I get no warnings or errors.
If however I compile it with
ifort sub.f90 /c /stand:f08
I get:
C:\TEMP\x>ifort sub.f90 /c /stand:f08
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.110 Build 20150815
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
sub.f90(2): warning #7025: This directive is not standard F2008.
sub.f90(4): warning #5268: Extension to standard: The text exceeds right hand column allowed on the line.
    print *,"if this line exceeds 132 characters, the directive makes the compilation fail                                         1"
sub.f90(4): error #5120: Unterminated character constant
compilation aborted for sub.f90 (code 1)
C:\TEMP\x>
If I remove the !DIR$ directive I get a warning about the line length, but no error
Johny
Kevin_D_Intel
It does look like a bug. I reported this to Development.
(Internal tracking id: DPD200378724)
johnyb_
I found this morning that the bug seems only to appear when using !DIR$, not with !DEC$.
According to the documentation !DEC$ is equivalent to !DIR$ so I will use this as a workaround
Kevin_D_Intel
Thank you for the added detail. I added that to the internal report. I'm glad you found the work around.
