29411 Discussions
./prep_chem_sources_radm_wrf_fim_.exe: error while loading shared libraries: libhdf5_fortran.so.300:
Odbaatar
Hello every one,
I am very new to Ubuntu and WRF Chem. Now i am installing prep_chem and this error has been occurred.
./prep_chem_sources_radm_wrf_fim_.exe: error while loading shared libraries: libhdf5_fortran.so.300: cannot open shared object file: no such file or directory
i already installed HDF5 Fortran.
But how do i solve this error.
please see this installad HDF5Fortran
phd_odbaatar@Odbaatar:~$ find / -name libhdf5_fortran.so\* 2>/dev/null
/usr/lib/x86_64-linux-gnu/hdf5/serial/libhdf5_fortran.so
/home/phd_odbaatar/miniconda3/pkgs/hdf5-1.14.6-mpi_mpich_h02efad0_4/lib/libhdf5_fortran.so.310
/home/phd_odbaatar/miniconda3/envs/ncl-env/lib/libhdf5_fortran.so.310
/home/phd_odbaatar/Models/WRF_TUTORIAL/Downloads/hdf5-1.13.2/fortran/src/.libs/libhdf5_fortran.so
/home/phd_odbaatar/Models/WRF_TUTORIAL/Downloads/hdf5-1.13.2/fortran/src/.libs/libhdf5_fortran.so.300
/home/phd_odbaatar/Models/WRF_TUTORIAL/Libs/grib2/lib/libhdf5_fortran.so
/home/phd_odbaatar/Models/WRF_TUTORIAL/Libs/grib2/lib/libhdf5_fortran.so.300
/home/phd_odbaatar/Models/WRF-CHEM_TUTORIAL/Downloads/hdf5-1.13.2/fortran/src/.libs/libhdf5_fortran.so.300.0.2
/home/phd_odbaatar/Models/WRF-CHEM_TUTORIAL/Downloads/hdf5-1.13.2/fortran/src/.libs/libhdf5_fortran.so.300.0.2T
/home/phd_odbaatar/Models/WRF-CHEM_TUTORIAL/Libs/grib2/lib/libhdf5_fortran.so.300.0.2
/home/phd_odbaatar/app/hdf5-1.13.2/fortran/src/.libs/libhdf5_fortran.so
/home/phd_odbaatar/app/hdf5-1.13.2/fortran/src/.libs/libhdf5_fortran.so.300
/home/phd_odbaatar/install/hdf5/lib/libhdf5_fortran.so
/home/phd_odbaatar/install/hdf5/lib/libhdf5_fortran.so.300
Arjen_Markus
You should set the LD_LIBRARY_PATH variable to include the path /home/phd_odbaatar/install/hdf5/lib/. This path is used to find the shared objects. You will probably want to extend the existing value.
Odbaatar
very thank you for your reply. I changed the directory
export LD_LIBRARY_PATH=/home/phd_odbaatar/Models/WRF_TUTORIAL/Libs/grib2/lib/:$LD_LIBRARY_PATH
but its not work. Where is my error? do you have any idea
Arjen_Markus
Can you run the ldd program:
> export LD_LIBRARY_PATH=... (as above)
> ldd ./prep_chem_sources_radm_wrf_fim_.exe
It may be that there are other libraries that are missing. The ldd program should list all that are needed and where they are coming from.
Odbaatar
I did according to your instructions
phd_odbaatar@Odbaatar:~/Models/WRF-CHEM_TUTORIAL/prep_chem/PREP-CHEM-SRC-1.5/bin$ export LD_LIBRARY_PATH=/home/phd_odbaatar/Models/WRF_TUTORIAL/Libs/grib2/lib/:$LD_LIBRARY_PATH
phd_odbaatar@Odbaatar:~/Models/WRF-CHEM_TUTORIAL/prep_chem/PREP-CHEM-SRC-1.5/bin$ ldd ./prep_chem_sources_RADM_WRF_FIM_.exe
linux-vdso.so.1 (0x00007ffd015fd000)
libnetcdf.so.19 => /lib/x86_64-linux-gnu/libnetcdf.so.19 (0x0000731da6015000)
libhdf5_fortran.so.300 => not found
libgfortran.so.5 => /lib/x86_64-linux-gnu/libgfortran.so.5 (0x0000731da5c00000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x0000731dae9f0000)
libmvec.so.1 => /lib/x86_64-linux-gnu/libmvec.so.1 (0x0000731da5b07000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x0000731dae9c0000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x0000731da5800000)
libhdf5_serial_hl.so.100 => /lib/x86_64-linux-gnu/libhdf5_serial_hl.so.100 (0x0000731dae99b000)
libhdf5_serial.so.103 => /lib/x86_64-linux-gnu/libhdf5_serial.so.103 (0x0000731da5400000)
libcurl-gnutls.so.4 => /lib/x86_64-linux-gnu/libcurl-gnutls.so.4 (0x0000731da5f5a000)
libxml2.so.2 => /lib/x86_64-linux-gnu/libxml2.so.2 (0x0000731da521e000)
/lib64/ld-linux-x86-64.so.2 (0x0000731daeaec000)
libcrypto.so.3 => /lib/x86_64-linux-gnu/libcrypto.so.3 (0x0000731da4c00000)
libcurl.so.4 => /lib/x86_64-linux-gnu/libcurl.so.4 (0x0000731da5a46000)
libsz.so.2 => /lib/x86_64-linux-gnu/libsz.so.2 (0x0000731dae994000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x0000731dae978000)
libnghttp2.so.14 => /lib/x86_64-linux-gnu/libnghttp2.so.14 (0x0000731dae94d000)
libidn2.so.0 => /lib/x86_64-linux-gnu/libidn2.so.0 (0x0000731da5f38000)
librtmp.so.1 => /lib/x86_64-linux-gnu/librtmp.so.1 (0x0000731dae92d000)
libssh.so.4 => /lib/x86_64-linux-gnu/libssh.so.4 (0x0000731da578f000)
libpsl.so.5 => /lib/x86_64-linux-gnu/libpsl.so.5 (0x0000731da5f24000)
libnettle.so.8 => /lib/x86_64-linux-gnu/libnettle.so.8 (0x0000731da51c9000)
libgnutls.so.30 => /lib/x86_64-linux-gnu/libgnutls.so.30 (0x0000731da4a06000)
libgssapi_krb5.so.2 => /lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x0000731da5175000)
libldap.so.2 => /lib/x86_64-linux-gnu/libldap.so.2 (0x0000731da5117000)
liblber.so.2 => /lib/x86_64-linux-gnu/liblber.so.2 (0x0000731da5a36000)
libzstd.so.1 => /lib/x86_64-linux-gnu/libzstd.so.1 (0x0000731da494c000)
libbrotlidec.so.1 => /lib/x86_64-linux-gnu/libbrotlidec.so.1 (0x0000731da5a28000)
libicuuc.so.74 => /lib/x86_64-linux-gnu/libicuuc.so.74 (0x0000731da4600000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x0000731da491a000)
libssl.so.3 => /lib/x86_64-linux-gnu/libssl.so.3 (0x0000731da4870000)
libaec.so.0 => /lib/x86_64-linux-gnu/libaec.so.0 (0x0000731da5a1f000)
libunistring.so.5 => /lib/x86_64-linux-gnu/libunistring.so.5 (0x0000731da4453000)
libhogweed.so.6 => /lib/x86_64-linux-gnu/libhogweed.so.6 (0x0000731da4828000)
libgmp.so.10 => /lib/x86_64-linux-gnu/libgmp.so.10 (0x0000731da43cf000)
libp11-kit.so.0 => /lib/x86_64-linux-gnu/libp11-kit.so.0 (0x0000731da422b000)
libtasn1.so.6 => /lib/x86_64-linux-gnu/libtasn1.so.6 (0x0000731da5779000)
libkrb5.so.3 => /lib/x86_64-linux-gnu/libkrb5.so.3 (0x0000731da4162000)
libk5crypto.so.3 => /lib/x86_64-linux-gnu/libk5crypto.so.3 (0x0000731da4136000)
libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x0000731da5a17000)
libkrb5support.so.0 => /lib/x86_64-linux-gnu/libkrb5support.so.0 (0x0000731da481b000)
libsasl2.so.2 => /lib/x86_64-linux-gnu/libsasl2.so.2 (0x0000731da411c000)
libbrotlicommon.so.1 => /lib/x86_64-linux-gnu/libbrotlicommon.so.1 (0x0000731da40f9000)
libicudata.so.74 => /lib/x86_64-linux-gnu/libicudata.so.74 (0x0000731da2200000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x0000731da1e00000)
libffi.so.8 => /lib/x86_64-linux-gnu/libffi.so.8 (0x0000731da480f000)
libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x0000731da40f2000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x0000731da40df000)
Arjen_Markus
It is still the same library that causes the trouble:
but the path that you added shows up in none of the output lines. Are you sure you have used the correct path name?
Odbaatar
Me too thought that path maybe wrong. But how do i modify it. i cant still modify it.
