29619 Discussions
preprocessor in fortran function #ifdef and #endif (Compiler:Compag Visual Fortran 6.6)
dingyzh1982
I get a fortran module, which rewrite below:
but when I compile this code , there are a error exist, I have open the "/fpp" and " /fpp:"/m" ",can we use the preprocessor (ex: #ifdef) in the function routine?, my OS is Windows XP, and Compiler: CVF 6.6, the error is below:
Error: Unrecognized token '#' skipped
the code text is below:
!module_ex.f90
module module_ex
contains
function Fun1(a &
#ifdef EOF
,b &
#endif
)result(c)
implicit none
real,intent(in) :: a
#ifdef EOF
real,intent(in) :: b
#endif
real :: c
c = a**2
#ifdef EOF
c = a**2+b
#endif
end function Fun1
end module module_ex
! main_program.f90
#define EOF
program main_program
use module_ex
implicit none
real a,b,c
a = 1
b = 2
c = Fun1(a &
#ifdef EOF
,b &
#endif
print *, c
end program main_program
Jugoslav_Dujic
Valued Contributor II
Quoting - dingyzh1982
!module_ex.f90
module module_ex
contains
function Fun1(a &
#ifdef EOF
,b &
#endif
I think that #ifdef works only on statement level. Try instead:
#ifdef EOF
function FUN1(a, b) result(c)
#else
function FUN1(a) result(c)
#endif
However, in this particular case, it is much better to take advantage of Fortran optional arguments:
[cpp]function Fun1(a,b) result(c)
real,OPTIONAL,intent(in) :: b
real :: c
c=a**2
if (PRESENT(b)) then
c = c+b
end if[/cpp]
jimdempseyatthecove
The major "fly in the ointment" is you are assuming
use module_ex
is conditionaly compiled with your main_program.
Modules (unless they are part of the same source file) are compiled independently from the source files that use them. Therefore, the #define EOF in main_program is not seen during the compilation of module_ex.
You can use the optional argument(s) technique as Jugoslav suggested or you can use the generic interface to have two different functions in module_ex be selected while using the same named function with differing sets of arguments.
[cpp]interface Fun1
  function Fun1_no_EOF(a) result(c)
    implicit none
    real, intent(in) :: a
    real :: c
  end function Fun1_no_EOF
  function Fun1_EOF(a,b) result(c)
    implicit none
    real, intent(in) :: a, b
    real :: c
  end function Fun1_EOF
end interface Fun1
[/cpp]
Then write the bodies of the funcitons in the module_ex
The #define EOF can be used in main_program which triggers call to Fun1(a,b) or Fun1(a). And these in turn end up calling Fun1_EOF(a,b) or Fun1_no_EOF(a) as the case may be.
The other route is write the two functions without the interface and then use
#ifdef EOF
#define Fun1(a,b) Fun1_EOF(a,b)
#else
#define Fun1(a) Fun1_no_EOF(a)
#endif
Then use Fun1(a) or Fun1(a,b) throught the program with or without conditionals.
--or--
#ifdef EOF
#define Fun1(a) Fun1_EOF(a,CommonEOFargHere)
#else
#endif
Then use Fun1(a) throught the program without conditionals
Note, FPP is case sensitive, FORTRAN is not
Your Fortran code could be required to use one of: FUN1, fun1, Fun1
You may have to create a #define for each
Jim Dempsey
