29435 ディスカッション
preprocessor warning!
ppthelion
ビギナー
3,859件の閲覧回数
I want to check if there is some parameter has already been defined,so I worked like this :
#ifdef NO64BITS
INTEGER, PARAMETER, public :: i8b = i4b
#else
INTEGER, PARAMETER, public :: i8b = SELECTED_INT_KIND(16)
#endif
But when I compile it ,the compliler shows :"warning, bad # preprocessor line" .I'm a newer to fortran,so I don't know what and how to do with it.Any answer is appreciated!
Have a nice day!
0 件の賞賛
1 解決策
TimP
名誉コントリビューター III
3,859件の閲覧回数
As this stuff isn't entirely standard, each compiler has a different way of enabling it. If you are using ifort, perhaps you intended to set /Qfpp (or enable pre-processing in Visual Studio), but forgot to do so or to tell us about it.
元の投稿で解決策を見る
10 返答(返信)
TimP
名誉コントリビューター III
3,860件の閲覧回数
John4
高評価コントリビューター I
3,859件の閲覧回数
You can try:
#if defined (NO64BITS)
ppthelion
ビギナー
3,859件の閲覧回数
Quoting - John
You can try:
It still act wrong as before after I done as your suggestion.........
John4
高評価コントリビューター I
3,859件の閲覧回数
Quoting - ppthelion
Make sure that the "#" symbol is in the first column, and that you are indeed invoking the preprocessor (with the /fpp command-line option)
ppthelion
ビギナー
3,859件の閲覧回数
Quoting - tim18
I have changed the 'preprocess source file ' --> (Yes/fpp),but it shows the same error.What I use is visual studio 2008+ intel fortran 11.1.051; I think it may be act as mkl_fftw_ms, so I try to connect with mkl_solver.lib mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib,but it doesn't worktoo.....I have no idea to do anything with it now ,help me!
ppthelion
ビギナー
3,859件の閲覧回数
Quoting - tim18
Sorry,it's my fault..... according to my command ,I has lost a flag 'Q' --/fpp not work ,/Qfpp work well !! But I found another intresting phenomena. In visual studio 2008+intel fortran 11.051,I want to change the preprocess like this : properties--> Fortran-->preprocessor-->preprocess source file,only /fpp options canbe chosen,and if you want to add /Qfpp,then command Line can do this!
Thanks!
ppthelion
ビギナー
3,859件の閲覧回数
In addition ,the document as follow may help people meet the same problem as me .it introduce the diff between /fpp and /Qfpp ,also the usage:
Runs the Fortran preprocessor on source files before compilation.
IDE Equivalent
Windows: Preprocessor > Preprocess Source File
Linux: None
Mac OS X: Preprocessor > Preprocess Source File
Architectures
IA-32, Intel 64, IA-64 architectures
Syntax
Linux and Mac OS X:
fpp
fpp[="option"]
-nofpp
Windows:
/fpp
/fpp[:"option"]
/nofpp
/Qfpp
/Qfpp[:"option"]
Arguments
n
Deprecated. Tells the compiler whether to run the preprocessor or not. Possible values are:
0
Tells the compiler not to run the preprocessor.
1, 2, or 3
Tells the compiler to run the preprocessor.
option
Is a Fortran preprocessor (fpp) option; for example, "-macro=no", which disables macro expansion. The quotes are required. For a list of fpp options, see Fortran Preprocessor Options.
Default
nofpp
The Fortran preprocessor is not run on files before compilation.
Description
This option runs the Fortran preprocessor on source files before they are compiled.
If the option is specified with no argument, the compiler runs the preprocessor.
If 0 is specified for n, it is equivalent to nofpp.Note that argument n is deprecated.
We recommend you use option Qoption,fpp,"option" to pass fpp options to the Fortran preprocessor.
Alternate Options
Linux and Mac OS X: -cpp
Windows: /Qcpp
Lorri_M_Intel
従業員
3,859件の閲覧回数
Quoting - ppthelion
Thanks!
I'm glad you're working, but I'm puzzled by what you've said here.
/fpp is equivalent to /Qfpp, and in fact we will be deprecating (slowly getting rid of) /Qfpp in a future release.
The documentation does list optional numbers after the "fpp" part, but those are ignored (and were there for compatibility with the V7.1 Fortran compiler).
Anyway, would you mind posting the build log from your case that was failing simply by setting Fortran-->preprocessor-->preprocess source file ? I'm curious about it .
thanks --
- Lorri
ppthelion
ビギナー
3,859件の閲覧回数
thanks --
- Lorri
I'm sorry for answering you so late,here is the compile log:
Compiling with Intel Visual Fortran 11.1.051 [IA-32]...
ifort /nologo /debug:full /Od /Qfpp /gen-interfaces /warn:interfaces /module:"Debug" /object:"Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c /extfpp:cfortran.h,cfitsio.h /fpp /libs:dll cfitsio.lib /MD /iface:cvf /Qvc9 /Qlocation,link,"C:Program Files (x86)Microsoft Visual Studio 9.0VCbin" "E:lib_newHealpix_2.13asrcf90modhealpix_types.F90"
E:lib_newHealpix_2.13asrcf90modhealpix_types.F90(45): #error: '#ifdef' argument starts with wrong symbol.
Console1 : error PRJ0019: A tool returned an error code
and the original code is:
#ifdef (NO64BITS)
#else
#endif
Thanks for your attention!
IanH
名誉コントリビューター III
3,859件の閲覧回数
Quoting - ppthelion
#ifdef (NO64BITS)
Remove the parentheses around the #ifdef argument, ie:
#ifdef NO64BITS
返信
