29651 Discussions
problem during multi file optimization compilation (code 3)
kapa2010
Hi everyone,
I use ifort compiler and while trying compiling megan (emisson model) code i see this error :
ifort: error: problem during multi-file optimization compilation (code 3)
Any idea? I use 2 linked libraries (netcdf and ioapi)
This error is almost always preceded by a more meaningful compiler error, which is what you should look at. Are you using /Qipo?
kapa2010
Hi thanks for your replyment,
In fact before that mesaage i see this:
fortcom:Severe: **Internal compiler error:Internal Abort** Please report this error along with the circumstances in which it occured in a Software problem Report
doesnt note any line of a file for example that there is a possible syntax error...
Ok. Would you please provide us with the source file being compiled, and the command line used? If it's a VS project, you can attach a ZIP of the project after doing a Build > Clean.
Which compiler version are you using? Include the update number.
kapa2010
I solved the problem..I installed again my libraries and i linked them again..Now runs without problems..
Thanks anyway
kallia
Ok - thanks. If you encounter "internal compiler error" again, and are using a current compiler version, please let us know.
