problem in format statment
dousti_a_
i define a subroutine
but it no work
subroutine printrmat(matrix,row,column)
    implicit none
    integer row,column,,i,j
    real(8) matrix(row,column)
    do i=1,row
        write(*,10) (matrix(i,j),j=1,column)
10 format(column(f))
    end do
    end subroutine
Johannes_Rieke
New Contributor III
Hi dousti,
try this (it works with Intel compilers but is not standard Fortran):
    implicit none
    integer, intent(in) :: row, column
    real(8), intent(in) :: matrix(row,column)
    integer :: i,j
    do i=1,row
        write(*,'(<column>ES16.8)') matrix(i,1:column)
    end do
    return
end subroutine
Regards, Johannes
IanH
The standard language offers an unlimited repeat count in format specifications, that can come in handy for these cases.
    implicit none
    integer :: i
    do i=1,row
        write(*,'(*(ES16.8))') matrix(i,:)
    end do
end subroutine
Johannes_Rieke
New Contributor III
Hi IanH,
didn't know of that standard feature 'unlimited format repeat count' before. I've googled it and it was introduced with F08. It is implemented since Composer XE2011 in the Intel compilers.
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/270542
Hopefully other compilers (e.g. gfortran, ...)  support it also in the stable releases.
dousti_a_
hi friends
tanks very much
i found a solution for problem
10 format(100(f))
or
10 format(1000(f))
or
Johannes_Rieke
New Contributor III
Hi dousti,
good that you found a solution. But in my opinion it would be better to use 'unlimited format repeat count', '*', instead of the fixed number. In case you plan to use this print routine in future, you could avoid trouble later on...
