29381 Discussions
problem in serial region of openmp problem
roddur
As my last post, i have found the problemetic area and hopefully you have not got irritated with me and this problem.
Here is the part of my code which i think relevent!
!$omp parallel do default(shared) &
!$omp private(il,ienrp,istart,iend,iie,xxa,yya) &
!$omp private(xa,ya,e)
orbital: do il=1,lorbit-2,2
xa=0.00;ya=0.00
write(*,'(1x,"Starting orbital loop",1x,i2,$)') il
ienrp=0
e=emin-de
istart=1
iend=lorbit
! do iend=9,63,lorbit
111 continue
e=e+de
iie=0
do ie=istart,iend
iie=iie+1
p2(iie)=ap2(ie)
p3(iie)=ap3(ie)
p4(iie)=ap4(ie)
enddo
ienrp=ienrp+1
call hop(il,e,ienrp,map,srl,ap1, &
ap6,ap7,ap8,ap9,ap10,ap11, &
ap12,ap13,p2,p3,p4,xa,ya)
istart=iend+1
iend=iend+lorbit
write(*,'(".",$)')
! end do
if (iend<=npn)goto 111
call fit(xa,ya,seed,xxa,yya,temp,il)
call spectral(il,xxa,yya,temp,spec)
write(*,'("done")')
end do orbital
!$omp end parallel do
call tdos(spec,ipq,nsp,dos, &
sorb,porb,dorb,osd1,osd2)
! Writing DOS to the files
call ldos(dos_aa,dos_b,dos_adn,dos_bdn,temp,T_dos)
call fermi(temp,T_dos,ef)
call band(temp,T_dos,ef,e_band)
call pardos(temp,sorb,porb,dorb,ef,nit,e_band, &
qtot_a,qtot_b,qtot_a1,qtot_b1)
it calls the subroutine pardos:
! This program calculates the partial dos and
! MAGMOM and written by Kartickda.
! I will update it latter!
! No documentation meanwhile
subroutine pardos(temp,sorb,porb,dorb,ef,nit,e_band, &
use parameters
implicit double precision(a-h,o-z)
dimension temp(nfn+1),sorb(2,nfn+1,2), &
porb(2,nfn+1,2), &
dorb(2,nfn+1,2),a(3)
do nsp=1,2
ia=-1
ib=-1
qtot_a=0.0d0
qtot_b=0.0d0
do ij=1,2
if(ij.eq.1)then
yx=x
open(1,file='POTPAR_A',status='old')
read(1,*)a(1)
read(1,*)a(2)
read(1,*)a(3)
if(nsp.eq.2)then
read(1,*)a(1)
read(1,*)a(2)
read(1,*)a(3)
endif
close(1)
else
yx=y
open(1,file='POTPAR_B',status='old')
read(1,*)a(1)
read(1,*)a(2)
read(1,*)a(3)
if(nsp.eq.2)then
read(1,*)a(1)
read(1,*)a(2)
read(1,*)a(3)
endif
close(1)
endif
in=1
do ii=1,3
! s=dreal(ii)
call mom(temp,sorb,a,ii,ef,ij,in,yx,ia,ib,qtot_a,qtot_b, &
qtot_a1,qtot_b1,e_band,nit,nsp)
enddo
in=in+1
do ii=1,3
! s=dreal(ii)
call mom(temp,porb,a,ii,ef,ij,in,yx,ia,ib,qtot_a,qtot_b, &
enddo
in=in+1
do ii=1,3
!c s=dreal(ii)
call mom(temp,dorb,a,ii,ef,ij,in,yx,ia,ib,qtot_a,qtot_b, &
qtot_a1,qtot_b1,e_band, nit,nsp)
enddo
!c in=in+1
!c do ii=1,3
!c s=dreal(ii)
!c call mom(temp,forb,a,ii,ef,ij,in,yx,ia,ib,qtot_a,qtot_b,
!c . qtot_a1,qtot_b1,
!c . e_band, nit,nsp)
!c enddo
enddo
enddo
end subroutine pardos
! CONTAINS
subroutine mom(temp,dos1,a,ii,ef,ij,in,yx,ia,ib,qtot_a, &
qtot_b,qtot_a1,qtot_b1,e_band,nit,nsp)
use parameters
dimension temp(nfn+1),a(3),dos1(2,nfn+1,2),A_MOM(0:8,2), &
B_MOM(0:8,2),ECG_A(3,2),ECG_B(3,2)
de=temp(2)-temp(1)
de=dabs(de)
sum1=0.0d0
sum11=0.0d0
!*****************Two calculate ECG*************************************
!***************** ECG=(band energy) /(charge in that band)*****************
if(ii.eq.3)then
do i=1,nfn+1
sum11=sum11+yx*dos1(ij,i,nsp)*de*temp(i)
if(temp(i).gt.ef) then
y1=dos1(ij,i-1,nsp)
y2=dos1(ij,i,nsp)
x1=temp(i-1)
x2=temp(i)
xx=ef
yb=y1+((xx-x1)*(y2-y1))/(x2-x1)
de=dabs(ef-temp(i-1))
sum11=sum00+yx*yb*de*xx ! here de must be different from previous
goto 1000
endif
sum00=sum11
enddo
endif
1000 continue
do i=1,nfn+1
sum1=sum1+yx*dos1(ij,i,nsp)*de*(temp(i)-a(in))**(ii-1)
y1=dos1(ij,i-1,nsp)
y2=dos1(ij,i,nsp)
x1=temp(i-1)
x2=temp(i)
xx=ef
sum1=sum0+yx*yb*de*(xx-a(in))**(ii-1) ! here de must be different from previous
goto 100
endif
sum0=sum1
enddo
100 continue
value=sum1
if(ij.eq.1.and.ii.eq.3)ECG_A(in,nsp)=(1.0d0/x)*sum11
if(ij.eq.2.and.ii.eq.3)ECG_B(in,nsp)=(1.0d0/y)*sum11
write(*,'(4(f8.3),1x,i1,1x,i1)') ECG_A(in,nsp),x,sum11,in,nsp
if(ij.eq.1)then
ia=ia+1
if(ia/3*3.eq.ia)qtot_a=qtot_a+value
A_MOM(ia,nsp)=(1.0d0/x)*value
endif
if(ij.eq.2)then
ib=ib+1
B_MOM(ib,nsp)=(1.0d0/y)*value
if(ib/3*3.eq.ib)qtot_b=qtot_b+value
endif
!c if(ij.eq.2.and.ib.eq.11.and.nsp.eq.2)then
if(ij.eq.2.and.ib.eq.8.and.nsp.eq.2)then
open(2,file='/home/rudra/Recursion/LMTO_A/MAINA/EB_A',status='unknown')
do ii=1,2
do ikk=1,3
write(2,*)ECG_A(ikk,ii)
enddo
enddo
close(2)
open(2,file='/home/rudra/Recursion/LMTO_B/MAINA/EB_B',status='unknown')
do ii=1,2
do ikk=1,3
write(2,*)ECG_B(ikk,ii)
enddo
enddo
close(2)
ECG_A(1,1)=ECG_A(1,1)/A_MOM(0,1)
ECG_A(2,1)=ECG_A(2,1)/A_MOM(3,1)
ECG_A(3,1)=ECG_A(3,1)/A_MOM(6,1)
ECG_B(1,1)=ECG_B(1,1)/B_MOM(0,1)
ECG_B(2,1)=ECG_B(2,1)/B_MOM(3,1)
ECG_B(3,1)=ECG_B(3,1)/B_MOM(6,1)
ECG_A(1,2)=ECG_A(1,2)/A_MOM(0,2)
ECG_A(2,2)=ECG_A(2,2)/A_MOM(3,2)
ECG_A(3,2)=ECG_A(3,2)/A_MOM(6,2)
ECG_B(1,2)=ECG_B(1,2)/B_MOM(0,2)
ECG_B(2,2)=ECG_B(2,2)/B_MOM(3,2)
ECG_B(3,2)=ECG_B(3,2)/B_MOM(6,2)
qtot_a=A_MOM(0,1)+A_MOM(3,1)+A_MOM(6,1)
qtot_a=qtot_a-A_MOM(0,2)-A_MOM(3,2)-A_MOM(6,2)
qtot_b=B_MOM(0,1)+B_MOM(3,1)+B_MOM(6,1)
qtot_b=qtot_b-B_MOM(0,2)-B_MOM(3,2)-B_MOM(6,2)
dmag=x*qtot_a+y*qtot_b
qtot_aa=A_MOM(0,1)+A_MOM(3,1)+A_MOM(6,1)
qtot_aa=qtot_aa+A_MOM(0,2)+A_MOM(3,2)+A_MOM(6,2)
qtot_bb=B_MOM(0,1)+B_MOM(3,1)+B_MOM(6,1)
qtot_bb=qtot_bb+B_MOM(0,2)+B_MOM(3,2)+B_MOM(6,2)
a_mag=qtot_a
b_mag=qtot_b
open(1,file='data_ef',status='unknown',access='append')
write(1,79)nit,ef,x*qtot_a,y*qtot_b,dmag,x*qtot_aa,y*qtot_bb
close(1)
79 format(i4,2x,6(f19.13,2x))
qtot_a=qtot_a+A_MOM(0,2)+A_MOM(3,2)+A_MOM(6,2)
qtot_b=qtot_b+B_MOM(0,2)+B_MOM(3,2)+B_MOM(6,2)
qtot_a=x*(qtot_a+c_a-z_a)
qtot_b=y*(qtot_b+c_b-z_b)
w_a=2.5952955d0
w_b=w_a
e_mad_A=x*y*ruban*2.0d0*qtot_a*qtot_a/w_a
e_mad_B=e_mad_A
open(1,file='MAD',status='unknown',access='append')
write(1,7979)nit,e_mad_A
close(1)
7979 format(i4,2x,f19.13)
vm_a=qtot_a*ruban/w_a
vm_b=qtot_b*ruban/w_b
if(nit.eq.0)then
qtot_a1=0.0d0
qtot_b1=0.0d0
endif
vm_a1=(amix*qtot_a1+(1.0d0-amix)*qtot_a)*ruban/w_a
vm_b1=(amix*qtot_b1+(1.0d0-amix)*qtot_b)*ruban/w_b
!c vm_a1=amix*vm_a+(1.0d0-amix)*qtot_a1
!c vm_b1=amix*vm_b+(1.0d0-amix)*qtot_b1
qtot_a1=qtot_a
qtot_b1=qtot_b
!c qtot_a1=vm_a
!c qtot_b1=vm_b
open(1,file='/home/rudra/Recursion/LMTO_A/ATOM/CH_A',status='unknown')
open(2,file='/home/rudra/Recursion/LMTO_B/ATOM/CH_B',status='unknown')
write(1,*)a_mag
write(1,*)c_a
write(1,*)vm_a
write(1,*)vm_a1
write(2,*)b_mag
write(2,*)c_b
write(2,*)vm_b
write(2,*)vm_b1
close(1)
close(2)
open(1,file='/home/rudra/Recursion/LMTO_A/BNDASA/ASM_A',status='unknown')
do ii=1,2
do ik=0,8
write(1,*)A_MOM(ik,ii)
enddo
enddo
close(1)
open(1,file='C_A',status='unknown',access='append')
write(1,790)nit,A_MOM(0,1),A_MOM(3,1),A_MOM(6,1), &
A_MOM(0,2),A_MOM(3,2),A_MOM(6,2), &
B_MOM(0,1),B_MOM(3,1),B_MOM(6,1), &
B_MOM(0,2),B_MOM(3,2),B_MOM(6,2)
close(1)
open(1,file='/home/rudra/Recursion/LMTO_B/BNDASA/ASM_B',status='unknown')
do ii=1,2
do ik=0,8
write(1,*)B_MOM(ik,ii)
enddo
enddo
close(1)
!c open(1,file='C_B',status='unknown',access='append')
!c write(1,790)nit,(B_MOM(ik),ik=0,8)
!c close(1)
open(1,file='/home/rudra/Recursion/LMTO_A/MAINA/ECG_A',status='unknown')
do ii=1,2
do ik=1,3
write(1,*)ECG_A(ik,ii)
write(*,*)ECG_A(ik,ii),'ECG_A'
enddo
enddo
close(1)
open(1,file='/home/rudra/Recursion/LMTO_B/MAINA/ECG_B',status='unknown')
do ii=1,2
do ik=1,3
write(1,*)ECG_B(ik,ii)
write(*,*)ECG_B(ik,ii),'ECG_B'
enddo
enddo
close(1)
endif
790 format(i5,2x,17(f19.13,2x))
return
end subroutine mom
the confusion is with the line bold "write(*,'(4(f8.3),1x,i1,1x,i1)') ECG_A(in,nsp),x,sum11,in,nsp"! on the line before, i have calculated ECG_A as sum11/x. In serial and parallel run, x and sum11 is same but ECG_A is going wrong for parallel run. As this pardos is called outside the parallel region and ECG_A is *NOT* used in parallel part, it is confusing for me. I am also giving the logfile showing the value of ECG_A,x and sum11 as the output of the given line.
Here is the output of parallel run:
    2.710823505304238E-312 0.400000005960464 0.000000000000000E+000
    -0.166231881280857 0.400000005960464 -6.649275350316219E-002
    0.000000000000000E+000 0.400000005960464 0.000000000000000E+000
    -0.129265494057355 0.400000005960464 -5.170619839342450E-002
    4.940656458412465E-324 0.400000005960464 0.000000000000000E+000
    -0.699069491020269 0.400000005960464 -0.279627800574887
    -0.166231881280857 0.400000005960464 0.000000000000000E+000
    -0.166231881280857 0.400000005960464 -7.268694868701296E-002
    0.000000000000000E+000 0.400000005960464 -5.663180366422458E-002
    -0.699069491020269 0.400000005960464 0.000000000000000E+000
    -0.699069491020269 0.400000005960464 -0.290675137405829
    -0.175132734976240 0.400000005960464 -7.005309503436828E-002
    -0.135999333762297 0.400000005960464 -5.439973431553807E-002
    2.759542400706198E-317 0.400000005960464 0.000000000000000E+000
    -1.27379738479930 0.400000005960464 -0.509518961512145
    -0.175132734976240 0.400000005960464 0.000000000000000E+000
    -0.175132734976240 0.400000005960464 -7.264274923186119E-002
    0.000000000000000E+000 0.400000005960464 -5.763164287005654E-002
    2.759542400706198E-317 0.400000005960464 -0.290288221373248
and that for serial run is:
-0.166231192935238 0.400000005960464 -6.649247816491034E-002
-0.129261884867856 0.400000005960464 -5.170475471760318E-002
-0.699020494933910 0.400000005960464 -0.279608202140051
-0.166231192935238 0.400000005960464 0.000000000000000E+000
-0.166231192935238 0.400000005960464 -7.268663541871814E-002
-0.129261884867856 0.400000005960464 0.000000000000000E+000
-0.129261884867856 0.400000005960464 -5.664037525321141E-002
-0.699020494933910 0.400000005960464 0.000000000000000E+000
-0.699020494933910 0.400000005960464 -0.290722991209875
-0.175131874417321 0.400000005960464 -7.005275081079569E-002
-0.135994161904373 0.400000005960464 -5.439766557233750E-002
-1.27376705297917 0.400000005960464 -0.509506828783912
-0.175131874417321 0.400000005960464 0.000000000000000E+000
-0.175131874417321 0.400000005960464 -7.264237921621851E-002
-0.135994161904373 0.400000005960464 0.000000000000000E+000
-0.135994161904373 0.400000005960464 -5.762860036718714E-002
-1.27376705297917 0.400000005960464 0.000000000000000E+000
-1.27376705297917 0.400000005960464 -0.290264316339248
(Cant manage the format...plz forgive me!) on the first column is ECG_A which depends on 2nd and 3rd column.....but its different in serial and parallel run though 2nd and 3rd column is identical.
Cau you people suggest me something?
jimdempseyatthecove
At start of program
ECG_A = -1.0
ECG_B = -1.0
And see if you get something different
The result 2.710823505304238E-312 is approximately equivilent to TINY()
You may have an uninitialize variable issue.
Jim Dempsey
rreis
in that case compiling with
-check uninit
wouldn't catch the culprit?
TimP
Quoting - rreis
-check uninit
You and I wish. Have you been able to use -check uninit within a parallel region (without too many false positives)? Thread checker may catch some private uninitialized variables.
roddur
1 #FC=gfortran
2 FC=/opt/intel/Compiler/11.0/074/bin/intel64/ifort
3
4 ifeq ($(FC),gfortran)
5 CC=gcc
6 FFLAGS =-O3
7 FPAR=#-fopenmp
8 LFFLAG=-O3
9 CFLAG =-O3
10 else
11 ifeq ($(FC),/opt/intel/Compiler/11.0/074/bin/intel64/ifort)
12 CC=gcc
13 FFLAGS = -O3 -check uninit
14 LFFLAG= -O3 -static
15 FPAR=-openmp
16 CFLAG =#-O3
This is my compilar options: -check uninit is not giving any other information
jimdempseyatthecove
roddur,
I notice that in your parallel do you use ie as a loop control variable. ie has not been declared as private.
This may present a problem.
[cpp]iie=0
do ie=istart,iend ! *** ie is shared ***
  iie=iie+1
  p2(iie)=ap2(ie)
  p3(iie)=ap3(ie)
  p4(iie)=ap4(ie)
enddo
---- consider  using ---
iie = iend-istart+1
p2(1:iie) = ap2(istart:iend)
p3(1:iie) = ap3(istart:iend)
p4(1:iie) = ap4(istart:iend)
[/cpp]
Jim
roddur
hello jim,
i tried that one as well but not with much help. can i send you all the files? hopefully then you can suggest me something.
i dont want to put the whole code here. so will you plz allow me to send it you personally?
jimdempseyatthecove
Quoting - roddur
hello jim,
I don't mind taking a quick look - assuming it compiles and includes any input files. I develop on Windows platform so there may be some issues in getting your make file to work. If you are using 3rd party libraries we may have a problem. I do have an Ubuntu Linuxsystem here, but I haven't gotten around to learning how to develop on it (documentation sucks).
Send to jim_dempsey@ameritech.net
Put "problem in serial region of openmp problem" in subject line.
Jim
Ron_Green
Jim,
I've updated a KB article on using Ubuntu with the Intel Compilers. The trick is that Ubuntu installs a rather standard Desktop linux environment. To get it ready for development, you have to load up gcc, g++ and the compatibility libs. The specific commands to do this are listed in the KB:
http://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu/
jimdempseyatthecove
Jim,
The problem is in trying to understand the IDE (placement of files etc... oops shouldn't use etc)
Comming from a Windows development much of what I view off the ide doesn't make sense.
When having an analog to a solution with multiple projects the IDE seems to want to stick everything in one folder. And the IDE won't let you create a folder on the fly. Something I am missing but this could be cleared up
With documentation with tutorial including "How to use IDE to create 'Hello World' program".
Then multi-project solutions.
Jim
