problem in setup
taherkhani
Hello everyone.
I want to use visual studio 2008 for write FORTRAN code and compile with Intel Visual Fortran.
When I setup Intel Visual Fortran Compiler v11.1.054-TBE, I get error:
Error 1311. Source file not found:
Because two files that names are data1.cab in Folders
1. w_cpromkl_common_p_10.2.054
2. w_cpromkl_ia32_p_10.2.054
have sizes 0 kb.
Please Help Me.
I don't recognize the -TBE in the name you give. Where did you get this installer from? It sounds as if the download is corrupted - please delete that installer and download again from the Intel Registration Center. The current version is 12.0, but you can get later updates to 11.1 as well.
