29649 Discussions
problem linking fortran files after compilation
ivf_ian
This communication is a few weeks since my last.  First of all thanks to those who have helped me earlier with the compilation issues I was having with Fortran.  I believe I have managed to solve them. but now I am having a problem with linking the files together.  See below.
 Compiling with Intel® Fortran Compiler 2025.3.2 [Intel(R) 64]...08:02:38:642     osd_a.f9008:02:44:345     Linking...08:02:44:549     osd_a.obj : error LNK2019: unresolved external symbol DIALOGBOXPARAM_G referenced in function _WinMain@1608:02:44:555     msvcrtd.lib(exe_winmain.obj) : error LNK2019: unresolved external symbol WinMain referenced in function "int __cdecl invoke_main(void)" (?invoke_main@@YAHXZ)08:02:44:559     x64\Debug\opticsoft.exe : fatal error LNK1120: 2 unresolved externals08:02:44:562     08:02:44:562     Build log written to  "file://C:/opticsoft/i2610/opticsoft/x64/Debug/BuildLog.htm"08:02:44:562     opticsoft - 3 error(s), 0 warning(s)08:02:44:570     ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========08:02:44:570     ========== Build completed at 8:02 AM and took 06.438 seconds ==========
Because the Fortran compiler objected to my use of DIALOGBOXPARAM (used previously with IVF), I changed the call to DIALOGBOXPARAM_G found in user32.f90 file.  However, I am not sure whether or not this was a good move.
As for the other error, signified by msvcrtd.lib. I haven’t a clue what that is about.  When I received this error first of all, I added what I imagined was the appropriate link to the option for additional include directories within the compiler, but this cause of action had no effect.  Both errors appear in the file osda.f90, which contains the routine winMain.
Would appreciate any help to resolve the above two problems.
andrew_4619
You need to post the code where you call this, it is without doubt a problem with the call args and the declarations of the same.
ivf_ian
Attached is the file which I believe generates the problems.  This was written by a colleague some 20 years ago, and I have made minor modifications in the hope of making it compatible with the latest IVF.  However, I'm somewhat at sea with combining C with Fortran.  If it would help I can send the other files within the program.   Thanks for your assistance.
Shiquan_Su
Would you please include all the necessary files and instructions for the settings to reproduce the issue?
