problem with EM64T developemnt
r_robinson
I have an evaluation copy of the fortran compiler v9.1. I installed it on an AMD
64 machine running XP 64 and Visual Studio 2005. I can use either VS or
the command line window for making IA32 applications OK. When I try to
open the commnad line window for EM64T I get "directory not found" which is
true because the bat file is looking for C:Program FilesMicrosoft SDK.... whick does not exist. Likewise, in VS, Ican switch the project environment to
EM64T but then I get told that the fortran compiler for this is not installled.
I don't want to buy the compiler if I can't get it to work for EM64T. Can anyone tell me what I need to do?
Thanks!
r_robinson
OK, after reading some Intel info pages, I uninstalled the compiler, updated VS 2005 to include EM64T support, reinstalled the compiler, and all is going well. Note that this VS update requires checking things under the C++ tab!
Sorry to post questions that just show my dumbness! However, I think there may be others in the same boat.
RR
The Installation Guide discusses this in some detail, but I know that few people read the guides.
chang1
Steve,
I still have problem with the EM64T. The VS2005 professonal version was reinstalled. Now I can choose x64 in Configuration manager. I also uninstalled compiler intergration and reinstalled it (both A32 and EM64T was installed previously). However, when I try to build a solution, it says the X64 compiler is not installed. Can you give me some help? Thanks.
regards
Chang
Please reinstall the compiler. Since you didn't have EM64T support there before, it didn't install the EM64T compiler. As a shortcut, run C:Program FilesIntelDownloadIntelFortranCompiler91CompilerEM64Tsetup.exe
chang1
Steve,
I reinstalled the compiler (both the EM64T and the integration), but still have the same probem: compiler EM64T not installed. I also noticed that when we I chose X64 in the configuation manager (I did that by select new>x64>copy from X32 setting), the Target machine in the Linker>Advanced is "not set". The only other option I can select is "MachineX86". Why didn't it change to "Machinex64" automatically or let me havetheoption to select "Machinex64"?
regards
Zenghu
I suggest you contact Intel Premier Support for further help on this.
