problem with automatic reallocation in statement "A = fun(A)"
riad_h_1
Dear all,
I am using ifort 19.0.5 for mac OS and I encountered a problem (that seems to be a bug) with statements of the type A = fun(A) where
- A is an allocatable array,
- the result of fun is of a shape (and/or a size) different from A,
like in statements A = reshape(A,..) or A = transpose(A).
I have not observed any problems with gfortran (9.2) and nagfor (6.2).
With ifort the array A is re-allocated to the right shape but its values are sometimes wrong. For example, with A = transpose(A) I always get wrong values.
This is not the case with A = reshape(A,...) which seems more insidious since the result is only sometimes wrong (the same test program run several times can give the right result or can give A = 0)
My question is simply: is it really a bug? The option -assume realloc-lhs does not resolve this problem (if I understood this is now the default).
Obviously I can use the workaround : tmp = f(A) ; call move_alloc (from=tmp, to=A) , but in the code I use, there is a significant number of this type of instructions (with fun intrinsic or user function) and therefore a lot of changes to be made...
Riad
Steve_Lionel
No example. Hmm..
Ok, let's try:
integer, allocatable :: a(:,:)
a = reshape ([1,2,3,4,5,6],[3,2])
a = transpose(a)
print *, shape(a)
print *, a
end
D:\Projects>ifort t.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.5.281 Build 20190815
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.23.28107.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-subsystem:console
t.obj
D:\Projects>t.exe
           2           3
           1           4           2           5           3           6
Looks ok to me. What do you see when you try this? If it works for you, please show us a complete test case that demonstrates the failure.
riad_h_1
Hi Steve,
yes your example works. But when I change  a = reshape ([1,2,3,4,5,6],[3,2]) to a = reshape ([1,2,3,4,5,6],[2,3]) and I compile with -check all the result is not the expected one.
Here are two examples:
1) realloc_transpose.f90 (very similar to yours for which the problem arise when compiling with -check all)
! compilation: ifort -check all realloc_transpose.f90
! (if -check all is omited, the problem goes away!)
implicit none
integer :: mat(2,3) = reshape([1,4,2,5,3,6],[2,3]), trans_mat(3,2), i, j
integer, allocatable :: A(:,:)
trans_mat = transpose(mat)
A = mat
print*,'Let A:'
do i = 1, size(A,1) ; print*,(A(i,j),j=1,size(A,2)) ; end do
A = transpose(A)
if (any(A - trans_mat /= 0)) then
   print '(a   )','Error: A = transpose(A) does not give the expected result:'
end if
end
And here is the output:
 Let A:
           1           2           3
           4           5           6
           1           4
           2           5
           2           6
2) realloc_reshape.f90 where I run several times the same statements until an error is detected:
! compilation: ifort realloc_reshape.f90
implicit none
integer, parameter   :: nrow = 2, ncol = 3, ntimes = 2000000
integer              :: mat(nrow,ncol), mat_resh(ncol,nrow)
integer              :: i, j, iter
mat = reshape([(i,i=1,nrow*ncol)],[nrow,ncol])
mat_resh = reshape(mat,[ncol,nrow])
do iter = 1, ntimes
   A = mat
!- Reshape A and put the result back into A (automatic re-allocation)
!  Sometimes the result is wrong (A=0) with ifort 19
   A = reshape(A,[ncol,nrow])
!- Stop if A /= mat_resh:
   if (any(A - mat_resh /= 0)) then
      print '(a,i0)','Error at iteration #',iter
      print*,'A = reshape(A,[ncol,nrow] gives:'
      print*,'which is not the expected result:'
      do i = 1, size(mat_resh,1) ;  print*,(mat_resh(i,j),j=1,size(mat_resh,2)) ; end do
      stop
   end if
   deallocate(A)
end do
print*,'Terminated with no error'
Error at iteration #13722
           0           0
           0           0
           0           0
           1           4
           2           5
           3           6
Best regard,
Riad
Ferdinand_T_
New Contributor II
Steve_Lionel
Thanks for providing a reproducer. I suggest you report it to Intel using the Online Service Center. And in the future, please provide test cases, no matter how simple you think the problem is!
riad_h_1
Ferdinand T. wrote:
This may be related to the issues with -check shape reported earlier:
https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/840198
https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/831548
Thanks Ferdinand. Yes for the 1st case, it seems to be the same problem that appears only with the "check shape" option.
However, the second case may be a different problem, as it occurs even without any options and is random.
Best,
Riad
riad_h_1
Thank you Steve, I will report it. Best regards, Riad
