problem with function
milenko1976
Ok I have a problem like this.When I put function as a separate programe works fine(I have checked the results),when I put it as function in my big program,I get bad results,makes later numerical computaions senseless.I am attaching both versions.
These programs look too different to make meaningful comparison, and they print out different amounts of data. I suggest you run each of them through the debugger and see where differences in values start to appear.
mecej4
Such things do happen. It is the programmer's lot to take such events in stride, and hunt down and zap the offending source code. Some even find such activity enjoyable.
You may have better luck getting help here if you formulate concrete questions based on a description of work already done, than by simply depositing buggy code here.
milenko1976
I have solved this with debugger.
