29431 Discussions
problem with intel fortran compiler & matlab mex files
Michele_Catalano
Dear All,
I hope this is the right place... I'm trying to compile the basic example to test the linux configuration to build mex files with the intel fortran compiler.
I get the following error:
??? Invalid MEX-file '/home/catalanom/Scrivania/provaF/yprimef.mexglx': libifport.so.5: cannot open shared object file: No such file or directory
What is the problem? I configured the mexopts.sh file as follows>
FC='/opt/intel/Compiler/11.0/081/bin/ia32/
FFLAGS='-fpp -fPIC -u -w95 -warn all'
FLIBS="$RPATH $MLIBS -lm -L/opt/intel/Compiler/11.0/081/lib/ia32/"
FOPTIMFLAGS='-O3'
FDEBUGFLAGS='-g'
Thank you in advance for the help
Michele
TimP
As you have linked against a shared library in the ifort installation, you must have that directory in LD_LIBRARY_PATH environment (as 'source /opt/intel/Compiler/11.0/081/bin/ifortvars.sh ia32' would do), or set it up with ldconfig. If you had set up those environment variables by the ifort script, you would not require full paths in your own script.
Michele_Catalano
Quoting - tim18
Dear Tim,
thanks for your answer. I get the error yet; I source ifortvars.sh and I get
echo $LD_LIBRARY_PATH/opt/intel/Compiler/11.0/081/lib/ia32:/opt/intel/Compiler/11.0/081/mkl/lib/32:/opt/intel/Compiler/11.0/081/lib/ia32:/opt/intel/Compiler/11.0/081/mkl/lib/32:/opt/intel/Compiler/11.0/081/lib/ia32:/opt/intel/Compiler/11.0/081/lib/ia32:/opt/intel/Compiler/11.0/081/idb/lib/ia32/
It seems ok.
I compile with mex in verbose mode the followings commands
-> /opt/intel/Compiler/11.0/081/bin/ia32/ifort -c -I/usr/local/matlab7/extern/include -I/usr/local/matlab7/simulink/include -fpp -fPIC -u -w95 -warn all -O yprimef.F
-> /opt/intel/Compiler/11.0/081/bin/ia32/ifort -c -I/usr/local/matlab7/extern/include -I/usr/local/matlab7/simulink/include -fpp -fPIC -u -w95 -warn all -O yprimefg.F
-> /opt/intel/Compiler/11.0/081/bin/ia32/ifort -O -pthread -shared -m32 -Wl,--version-script,/usr/local/matlab7/extern/lib/glnx86/fexport.map -o yprimef.mexglx yprimef.o yprimefg.o /usr/local/matlab7/extern/lib/glnx86/version4.o -Wl,-rpath-link,/usr/local/matlab7/bin/glnx86 -L/usr/local/matlab7/bin/glnx86 -lmx -lmex -lmat -lm -L/opt/intel/Compiler/11.0/081/lib/ia32/
Is there any interaction? I'm not able to fix this, Thank you again
Michele
TimP
Dear Tim,
It seems ok.
Michele
I suppose you should check by 'file /opt/intel/Compiler/11.0/081/lib/ia32/libifport.so.5' that it is actually present as a 32-bit shared object.
If not, your ifort library installation is bad, and you should try uninstall and reinstall.
Michele_Catalano
Quoting - tim18
The library is present in the compiler distribution. The same code in fortran is linked successfully.
Michele
